What size DRs are you running on 15x10s?
Old Apr 19, 2003 | 09:49 AM
SPANKY LS1's Avatar
What size BFG DR are you running on a 15x10? I have 2 choices as I see it:
275/60/15 11.1" width measured on 8" rim, 28" dia
325/50/15 13.0" width measured on 10" rim, 27.9" dia
I'm worried that the 275 will look too narrow on a 10" wide rim. What will look better, in your opinion, Any pics? Thanks, Shawn
Old Apr 19, 2003 | 12:51 PM
rskrause's Avatar
Moderator
Re: What size DRs are you running on 15x10s?
I think you will have trouble getting 325's to fit.
Rich Krause
Old Apr 19, 2003 | 03:13 PM
mongse_1's Avatar
Brady McNew has 325s on his Z, but he's done a lot of work on the fender wells.
I'm running the 275s and had to do some modifications to get them to fit w/ a 10" wheel.
Old Apr 20, 2003 | 07:14 PM
anotherZfan's Avatar
i am running the 325's and think they look awsome!.....as far as work done to fit them...i had to pound the hell out of the inner wheel house and cut the bump out where the rear spring is, and remove the rubber snubber.....i also have eibach drag springs which raised it up a little........but believe me they look great especially from the back
Old Apr 20, 2003 | 09:27 PM
RacinLT1's Avatar
I run a 275/60 on a 15x10 for every day driving and it looks fine,doesnt bulge excessively or much at all.
Either 1 will work,just depends on how much tire you want.
Old Apr 20, 2003 | 10:56 PM
FASTFATBOY's Avatar
I have a 325/50 on 15x10 Weld XP's with 6.5 inch backspacing, they fit perfectly, I will take off the side snubbers, above that they fit.
David
Old Apr 21, 2003 | 06:27 AM
Brady's Avatar
Close Goose
I ran 325's on 15x8 welds with 5.5" backspacing. They fit fine, all I had to do was roll the fenderwell so they wouldn't rub when the suspension compressed.. I sold the 325's and I'm ordering a set of 315-60-15 drag radials.. I expect some fitting problems there..
I had to beat the holy hell out of my fenderwells to fit the 28x13.50 Hoosier QTP's on 15x10" welds with 7.5" backspacing. Those tires are for sale because I'm moving on to 29x10.5 slicks..
laterz
...Brady
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
