What should i run with 390rwhp @ 3400#
Whats most peoples ET's and MPH with ~385-400rwhp ~370rwtq and weigh around 3400 - 3500lbs
also list 60fts
trying to get an idea of what my car should run.
i wont be able to pull no better then a 1.8 60ft.. if that
car has 395rwhp 373rwtq is M6 weighs right around 3400 if the scales were right...
thanks
also list 60fts
thanks
The calculator at http://www.prestage.com/ uses a standard formula. Should give you an idea anyway. The mph tends to be low for a 4th gen, probalby better aerodynamics than the formula was written for.
One other thing: don't forget the weight of the driver, unless it's remote controlled.
Rich Krause
Rich Krause
Dang, do you have some weight reduction? That is light, even with a 95 lb person. My car weighed in at 3350 w/out me, and I thought it was light. With the weight that low, you should easily run 12.0s, even with a 1.8 60'. I see 120+ traps! Good luck!
How did you get your weight so low...
I have a hardtop, no bumper supports, racing seats, lightweight wheels and tires, no center console, carpet padding removed, no air, and the list goes on and on... 3590 with me in it... (200 pounds). I would like to know what weight reduction measures you have taken.
395RWHP and 422RWTQ plus 3,700lbs(DAMN your light)
11.85@114 with 1.67 60ft.
I came out of the hole spinning. figure you should hit a 1.5x 60ft time and pull top end good(Mine shifted 2-3 at 6k not 6,900 like it should) and there is no reason you should not run low 11s.
I am going to guess 11.3s@117-119
maybe the scales are off then... I weigh 135 the scales said the car weighed 3260
what i have taken out the car is jack,spare, misc. plastic peices from the front, heatshields, noegr, no air, VFN fiberglass hood
car is t-top 94Z, cloth interior, no power options
so if tnthub takes all that out and still weighs over 3500 then the scales I was on are bound to be off... it had a certification thing on it so i figured it was right
for a refrence it said my brothers 56 chevy 2-10 4door hardtop(no post) w/ v8 and powerglide weighed 41xx if anyone knows what those are suppose to weigh
10-31-2016 11:09 AM
