What PSI for ET Streets?
Old May 23, 2003 | 11:16 AM
Shirl's Avatar
On the track, what PSI is recommended for ET Streets? (thanks)
Old May 23, 2003 | 11:28 AM
rskrause's Avatar
Moderator
Re: What PSI for ET Streets?
You've gotta experiment. I found 12.5lbs worked best with my 26x11.5x16. A noticible difference between 12, 12.5 and 13psi, hard to believe as that is.
Rich Krause
Old May 23, 2003 | 12:16 PM
rock1501's Avatar
I usually start about 20 psi and go down 1 psi every run till it hooks good.Our track prep is faily good here so I can usually get away with 18-19 psi but it kinda depends on your power level and if you have tubes.If you dont have tubes I wouldnt go below 14 psi.(to be safe).
Old May 23, 2003 | 02:37 PM
Derrick Redd's Avatar
It all depends on track prep as mentioned. I run 16 psi in my ET Drags.
KYWes
Jun 14, 2022 06:52 AM
bunker
Aug 21, 2015 10:21 AM
canuck94z28
Aug 19, 2015 05:50 PM
Louey
Pacific
Aug 7, 2015 01:47 AM
