what can i do to stiffen up the suspnsion on a 86 Ironc-z 5.7L?
Old Feb 23, 2008 | 10:41 PM
rbuenrostro's Avatar
Thumbs up what can i do to stiffen up the suspnsion on a 86 Ironc-z 5.7L?
if anyone knows the best bang for the buck, on fixing the suspension on my camaro. Im also putting a twin turbo on a 5.7. so i need it for that engine
Old Feb 24, 2008 | 01:58 AM
sn8ke eatr's Avatar
what exactly do you mean " i need it for that engine", the stiffer the suspension generally the less traction you will have when launching. are you dragging the car or auto cross type driving it, or will it be a basically street only car?
there are alot of companies that offer suspension packages for your car for a good price, go check out summit,
Old Feb 24, 2008 | 01:03 PM
91RSLT1's Avatar
If I were you I would box of the PHR and LCA with crome-moly, and install polyurathene bushings. Have relocation brackets and SFC welded on, and maybe install an ajustable TA. You could also put an airbag in the right rear. After that it gets $, such as 12-way shocks, drag springs, etc. However all this is only good/useful if you have a GOOD tire.
Old Feb 24, 2008 | 02:23 PM
sn8ke eatr's Avatar
thats accurate if your building a drag car, he said he wants to stiffen up the suspension, generally not good for drag racing
Old Feb 24, 2008 | 05:14 PM
91RSLT1's Avatar
Understood. IN that case lowering springs, bigger sway bars front/rear, poly bushings everywhere (endlinks, etc.), sub-frames, a wonder bar, and a strut tower brace. However my original post is still accurate in a street application. So I quess the REAL question sn8ke eatr is asking is what is your intended purpose for your TT build?????
Old Feb 24, 2008 | 10:47 PM
replying back on the advice.
Well the only purpose, is my brother. Well the TT camaro will be for him when he graduates high school. But he knows that the camaro is mine until that min. that he walks to get his diploma. But this car is his only inspiration. This is a 4 year project and i plan to finish it in 2012. As for what i meant when i say i need the suspension for the engine. I meant to say that i need a suspension that will hold and give me lots of traction. I know that tiers are an important aspect. I have been working on cars fro about 2 yrs now. But if u could pls. explain in more details what these parts are and how should i be using them
Old Feb 25, 2008 | 10:41 PM
sn8ke eatr's Avatar
so.. to the OP, your still not ansreing the question.
what is the car intended to do:
go fast in a strait line
be nice in the twisties
or do a mix of both
Old Feb 26, 2008 | 01:34 PM
Z28SORR's Avatar
The 86 IROC had a very good suspension, stock. I would simply replace the worn out components with stock replacement parts.
After your brother gets the car he may have his own idea's.
Also if ANYONE gave me a restored 86 IROC, I would be extremely pleased.
football4life
Oct 4, 2015 07:48 AM
Aug 5, 2015 08:35 AM
gelbza
Jul 12, 2015 08:10 AM
Richardan15
May 30, 2015 08:36 AM
rockync7
Jan 1, 2015 05:10 AM
