Track number for t56+3.23's
Old May 11, 2007 | 02:04 PM
MEAN LT1's Avatar
Went to the track Wed night and it was ok. I need a little more practice finding the right launch rpm and tire pressure. But anyway I was wondering if it was possible to get into the 12's with my setup?. Mods are in sig, my best two runs were 13.39@106 with a 2.2 60" and 13.33@104 with a 2.1 60". I was on et streets running about 19-20 psi. Next time I'll try lowering the pressure down to 15psi and see where that will get me.
Old May 11, 2007 | 05:48 PM
93LEETZ's Avatar
What RPM are you launching at with those 60's? I'm pretty sure your 60' should be around 1.6-7 with DR's if you launch correctly. If you get your 60' lower I don't see why you wouldn't be able to achieve a 12 second pass.
Old May 12, 2007 | 05:45 AM
AL SS590 M6's Avatar
Moderator
You assume drag radials. We've gotten lazy around here. There are 2 MT DOT drag race tires. One is the MT ET street a bias ply cheater slick the second is the MT ET street radial a drag radial.
But I was thinking the same thing, he's not launching hard enough.
Old May 12, 2007 | 09:10 AM
MEAN LT1's Avatar
Thanks for the suggestions, im on the stock clutch which is holding up for the time being. I'll try launching a bit higher like arounf 4k, that should help out with the gears out back.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
k1996z28
Apr 6, 2015 11:55 PM
