6 speed launches?
Old May 3, 2007 | 07:41 PM
HottestZ28's Avatar
6 speed launches?
I just did the t-56 swap and was wondering what the best way to launch was. I have 3.73 and BFG drags 255/55r16, also I have a line lock
what is a good starting point?
Old May 5, 2007 | 12:27 PM
396D1SS's Avatar
26x10.5s's mt et drags heat them up. rev to 6500.........drop clutch jk
i would line lock heat them up for about 4 seconds at 4000rpm in 1st gear,tires 19 psi, roll out, hold at 3600 rpm and slightly slip the clutch a tiny bit till you feel movement the drop
Old May 12, 2007 | 06:13 AM
Juiced91Z's Avatar
if you still have the stock 10 bolt i wouldnt launch any higher than 3000 on sticky tires. i've raced a few stock/bolt on 6 speed cars. Ive found that holding at about 3000, then ease the clutch out till you feel it start to pull the car forward, let out just a hair. Then when its go time, i let out the clutch agressively, not too much that it spins, not too little where it smokes the clutch, and then lay on the throttle, i've gottin consistant 2.0-2.1 60's on stock tires, but unless you dont care if it brakes, in that case, set up a 2 step and dump the clutch at like 5k and hold on!
Old May 14, 2007 | 03:38 PM
Shon Herron's Avatar
IF you have a spare rearend dump it at 6k and hold on, if you have a 12/9/S60 then set it at 6k+ and let it rip.
If you need a LL kit let me know.
Injuneer
May 15, 2015 08:45 AM
mark0006
Dec 25, 2014 09:50 PM
96z
Aug 2, 2002 09:00 PM
Camaro90RS
Jul 23, 2002 07:57 AM
