Tire Pressure in Nitto 555Rs
Old Apr 26, 2003 | 06:47 PM
maddboost's Avatar
I was wondering whats the best tire pressure to run on the street i have a set that I had the local tire place put on for me and they are running about 30psi. But it doesnt say the recommended pressure on the tires. Also should I run less pressure at the track to hook up better. They really hook great now but will they do better at the track if I drop to like 25 psi?
Old Apr 26, 2003 | 08:26 PM
25pounds's Avatar
I run mine from 14-30 PSi all of the time, but I do not do a lot of driving. After going to the track sometimes I will forget to air them back up for the street for a while. I can not tell a diff. in the way it drives, but like I said I do not put a lot of miles on them.
Old Apr 26, 2003 | 09:18 PM
Joe Brodman's Avatar
GP Moderator
On the street, 23-24psi. Seriously. Most people think that's a crock until they go through a set with them set at a higher pressure, and find the center of the tires wore out way before the outsides. The only way they seem to wear evenly is if you keep them at 23-24psi.
Old Apr 27, 2003 | 04:17 PM
Twice The Fun's Avatar
i put them between 15-18 on the track, and 23-25 on the street.
Old Apr 27, 2003 | 07:59 PM
rpm4lalo's Avatar
Mine are doing fine on the street at 25 psi.
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Brady
Jul 29, 2002 10:30 PM
MYT30TH
Jul 28, 2002 08:47 AM
