Is there a site that figures out correction factors?
Just curious if there is a site that would figure out what mph would equal what 1/4 mile time at 0 elevation.
Isn't there some NHRA site or table out there?
I have to assume you went to Prince George's track. It's listed as 2300 feet above sea level. What was the temperature, humidity and barometric pressure since those will change the density altitude?
http://www.nhra.com/tech_specs/altitude.html
Use the Stock/Super Stock conversion
Originally posted by Flat_Tire_
Anything out there to convert for 105 degrees F, first time to the strip, and bad 60' times?
There's not much you can do with a slippery track. Everyone is fighting the same conditions.
Deadbolt24
Jan 19, 2015 01:29 PM
