stock head cars with aftermarket cams
Old Feb 16, 2004 | 11:12 AM
  #16
1BADAIR's Avatar
Just wondering. I just installed my 4.11's. With the 3.42's I had a very low trap speed but I think i was from shifting into 4th right at the traps and the car not pulling. Hope the 4.11's help.
Old Feb 16, 2004 | 12:19 PM
  #17
LBJ's Avatar
LBJ
you will like them, they let you cross the traps in 4th around 6200rpm or so! No more shifting to 4th just before the traps And I promise your mph will jump up a couple!
Old Feb 18, 2004 | 12:02 AM
  #18
ba96ta's Avatar
I am hitting 4th gear at just after the 1/8 mile mark (stock 3.42"s) I think with 4.10's I would have to shift to fifth
1/8 85.1
1/4 107.8
Old Feb 20, 2004 | 05:00 PM
  #19
brain's Avatar
1/8 85.1
1/4 107.8
How is that possible? My car traps 105 - 106 and it will bounce off the rev limiter right at the traps, or I can shift into 4th. If you are in 4th well before the 1/4, shouldn't your trap speed be easy 120s? What tire do you run? I usually run 245/50/16s, but I was on 26x8.5 ET Drags on the 13.3 @ 104 in my sig. Do you short shift? I just don't see going to 4th at the 1/8th mile with those times.
Old Feb 20, 2004 | 07:50 PM
  #20
Z94SLEEPER's Avatar
ba96ta,,, I have 4.10 and still have some rpm's before the end of the 1/4.... Not to mention I'm trapping 3 mph more (4.10's help me out there). What are you shifting at through the gears??? I'm shifting anywhere between 5800-6200 depending on what the car feels like on that particular night/day.
Eric
Old Feb 21, 2004 | 07:42 PM
  #21
LBJ's Avatar
LBJ
Your gears are not 3.42's if you are shifting to 4th at the 1/8mile...with my 4.10's Iam crossing the traps around 6400rpm at the 1/4 track running 118mph.
Old Feb 22, 2004 | 11:39 PM
  #22
FastWhiteTA's Avatar
If he has a stock cam, and is trapping 85 in the 1/8 then yeah, he'll be shifting into 4th pretty quick after that. On a stock cammed LT1 3rd w/ 3.42s takes you to about 90 max at redline.
Old Feb 24, 2004 | 10:49 PM
  #23
96speed's Avatar
12.6 @ 112.5 on a 2.0 60'. M6 with 3.42 gears. ~65* ambient.
GTP6 cam. Never got to run the car after the dynotune (+20rwhp).
Ryan
Old Feb 25, 2004 | 10:25 AM
  #24
1BADAIR's Avatar
What's the stock rev limit on an LT1??
Old Feb 26, 2004 | 06:48 PM
  #25
LBJ's Avatar
LBJ
I take my statement back......I thought he was in a M6 LS1 and figured he had the same trans gearing as me???? Iam not sure about the LT1's......this is my first GM....r.i.p. 01 Cobra lol
Old Feb 26, 2004 | 08:43 PM
  #26
Kev70's Avatar
Does changing the cam cause the motor to spin bearings, or was it the head swap that was causing all of the problems? How much for labor?
Old Feb 26, 2004 | 10:29 PM
  #27
IllusionalTA's Avatar
w/ 3.42's and trapping upper 108's i was just shifting to 4th about 100-200ft before the trap's.. 3rd easily take you upto 90+mph w/ 3.42's on a 26" tire..
Old Feb 29, 2004 | 10:18 AM
  #28
LBJ's Avatar
LBJ
IllusionalTA,
That was my same case until I swapped in the 4.10's....The car would just start to pull in 4th and I would pass through the traps.
Old Feb 29, 2004 | 01:26 PM
  #29
Kain's Avatar
See sig.
Noenav
Dec 6, 2014 07:35 PM
chuyz28
Nov 25, 2014 11:14 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
Brian-94TA
Jul 31, 2002 02:52 PM
