Stalling a high stall converter
Old Jun 24, 2003 | 11:50 AM
5H9D0W's Avatar
Should I do this.I usually stall a 2200 before I go.Should I just let the converter do it's job or stall it a litte myself for better launch.
Old Jun 24, 2003 | 03:28 PM
Antz97ZNJ's Avatar
Stall it as high as it can go before breaking traction on the power break...its gonna take a few passes to get it dialed in perfectly what rpm u wanna launch at
Old Jun 24, 2003 | 08:21 PM
Stephen 87 IROC's Avatar
My converter stalls at 5700 on the transbrake. Depending on track conditions, I usually launch off the 2 step at 3000-3500 rpm and let the converter flash. That way it's a softer hit and I don't break traction as easily. If the track conditions are very good, I try to stall it right to 5700.
Old Jun 24, 2003 | 09:40 PM
ru2slo_99's Avatar
With my 2500 stall, I would rev it to about 1000 rpm, then when I saw the yellow lights I would nail it. If the track hooked I could do better flashing the converter like this then if I stall it up any higher. If the track is not hooking as good, I stall it up till about 1800-2000 rpm then ease on the gas.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
thenewkid
Apr 12, 2015 07:42 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Cam's maro
Dec 28, 2014 09:30 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
