Spirngs?
Old Sep 30, 2008 | 06:26 PM
95TA04GOAT's Avatar
Spirngs?
When i put my car together it was originally for an everday cruiser / occasional drag racing. But now i've had my GTO for about two years now and the trans am is pretty much just a weekend warrior. So right now the suspension setup is BMR lowering springs and bilstien shocks, adjustable panhard rod, bmr LCAs and relocation brackets, and bags in the rear springs.
My best 60' was a 1.78 with this setup. Would i see an improvement with putting the stock springs back in? I'd assume it would get better weight transfer with a softer rear spring.
Old Oct 1, 2008 | 02:45 AM
AL SS590 M6's Avatar
Moderator
Are you spinning the tires?
If you are hooking up like it is then suspension mods won't make any difference in your sixty or et.
If you are spinning then modding the suspension to help it hook will improve your times.
Old Oct 1, 2008 | 06:24 PM
95TA04GOAT's Avatar
It does hook pretty well but i can't leave off the line at WOT. I have to roll into it or else it'll spin badly. I'm running 255-50-16 MT ET Streets.
I'm just looking for some small things i can do relatively cheaply that'll help me get the most out of this thing. I'm going out to the track in a few weeks and i'd really like to break into the 11s. I have a CPT transmission on the way which i'm hoping will get me there. My best was a 12.1 before i put a bigger converter and taller gears in. After those mods the transmission started slipping in 3rd at the track, still managed a 12.1 though. So I'm hoping a transmission that holds up will let me net some gains from those gears and converter.
Old Oct 2, 2008 | 05:54 AM
Moderator
You don't need to loosen the back that'll just make it squat.
You need to loosen the front with some adjustable shocks and if you're running a front sway bar, remove it for your track days.
Old Oct 2, 2008 | 01:21 PM
slomarao's Avatar
Originally Posted by al ss590 m6
you don't need to loosen the back that'll just make it squat.
+1.
Old Oct 2, 2008 | 02:29 PM
The Engineer's Avatar
Spohn carries some Moog brand “constant-rate” rear springs for 4th Gen F-Bodies that work really well. Personally, I think the constant-rate are much better for drag racing than the factory variable-rate springs. And, my 60s are 1.50 to 1.48 at a really good track.
WD
383LT4head
Feb 25, 2007 06:39 PM
WI-Z-Guy
Feb 8, 2006 10:11 PM
84firebird
Classic Engine Tech
Jan 20, 2006 11:40 PM
IrocSS85
Jul 18, 2005 12:01 AM
