RPM @ Max HP
Old Mar 19, 2009 | 11:24 PM
deerslayinrenek's Avatar
RPM @ Max HP
What RPM should my car in my sig be making max HP and what would be a good point to shift at?......here in the next few weeks I'm gonna borrow a set of slicks and see what I can do..........thanks
Old Mar 20, 2009 | 08:01 AM
ABQ-F-body's Avatar
I am guessing max power is going to be made at 5100-5250 RPM's. I would shift at 5300-5400.
Really the thing that will change your RPM range is going to be a cam, the stuff you have already is great for supporting a cam, but doesn't expand the top end as much as it prevents it from dropping off as quick.
Old Mar 20, 2009 | 08:10 AM
JakeRobb's Avatar
Super Moderator
I agree with this.
But I don't agree with this. Run it right up to 5700 or whatever the stock redline is. If you get a tune, your upgraded springs, rockers, and lifters probably give you room to go even a little higher.
To know for sure, get a dyno graph. If power falls off drastically after the peak, then I'd recommend shifting earlier. But if it just falls off slowly, keep going. The gearing advantage you get from waiting far outweighs the slight decrease in power.
Old Mar 20, 2009 | 10:37 AM
alright I'll give it a try.....this was going to be my street/strip car and it was going to get a cam,N20 and a few other things but I just got a 71' Chevelle so all my funding has been turned to that........We have a 79' Camaro going to the track within the next few weeks to do a little test and tune and I figured I'd play around a little with my car.
Old Mar 20, 2009 | 07:51 PM
Z-RATED94's Avatar
I would start off shifting at 5700, then increase it 100 rpm the next run, etc, etc. I wouldn't think you'll have any luck taking it higher than 6000rpm though. Good luck.
Old Mar 28, 2009 | 12:00 AM
Well I must have done something right, I just won Street Stick at the local track, its my third time ever to a drag strip.....It was frickin sweet
Old Mar 28, 2009 | 09:15 AM
Z-RATED94's Avatar
Good for you! Did you get a chance to try the different shift points?
Old Mar 28, 2009 | 11:11 AM
Chevy85's Avatar
Exactly! Play with it a little and check your numbers, there is nothing worse than making a premature shift when you still had plenty of room left in your powerband. Congrats on the win by the way!!!
Old Mar 28, 2009 | 01:33 PM
Well actually I spent the entire night working on my 60fts which was a horrible 2.2-2.4.....I have a set of big heavy ugly 18" DUBS on it with a 245/40 tire and no matter what I do it wouldn't hook, I want to get a set of summit stars on it to make it look better and so I can get some drag radials......I made 7 passes and 5 of them were 14.0's......I know it'll dip in the 13's easy with a good set of tires......my goal last night was to break into the 13's but the best I could do was a 14.009 on a 14.00 dial-in...... I don't know if I should be happy or mad about that....but on the bright side I did send 2 Fox body mustangs and a mid 90's mustang home.........I shifted at 5700 but I did push it a little past once and it seemed to pick up so I'll try 5800-5900 next time..........I had a ton of fun running my slow 14.0 passes so I can't wait til I get my chevelle done....it'll be a blast
Old Mar 28, 2009 | 02:23 PM
Chevy85's Avatar
you are skipping the wet box, correct? Just a quick spin to clean any stuck on debris is all you need. If you wet and smoke you make radials "Milky" not sticky like a slick.
Old Mar 28, 2009 | 06:00 PM
yea last year i tried smoking them and that didn't help....last night i drove around the wet box and just cleaned them off......I just need to get a better set of tires for it
Old Mar 29, 2009 | 12:46 PM
this was the best run
Old Mar 30, 2009 | 06:45 AM
NVetro's Avatar
102 mph if i'm not mistaken is a solid 13.5-13.7 in the 1/4 isn't it? Your 60 foots seem week, work on those launches and it should bring your ET down.
Old Mar 30, 2009 | 05:10 PM
yes 60fts are horrible....it will not hook up, that slip was one of the better 60's......I want to get a lighter rim and a set of drag radials....actually the only reason i went was because we were taking a 79' Camaro down that was just built and I figured if i was gonna be down there I might as well have a little fun.....Now im glad I did
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
