overdrive or 3rd?
Old Jul 16, 2004 | 11:29 AM
dirtybird96's Avatar
overdrive or 3rd?
Is either gear better for launching? I've tried both and don't think I can tell a difference, but I wandered if 3rd would take off better?
Old Jul 16, 2004 | 12:29 PM
95GRNZ's Avatar
Arrow
No. It will start from 1st gear anyway.
TS
Old Jul 16, 2004 | 12:44 PM
Capn Pete's Avatar
^^^ what he said!
It makes no difference either way. When you put it in 3rd (Drive) or 4th (Over-drive), the tranny still starts in 1st, shifts, to 2nd, and shifts to 3rd automatically, it will just change whether it will shift into 4th or not, but in 1/4 mile, you won't hit 4th gear anyways.
Old Jul 16, 2004 | 07:48 PM
Stephen 87 IROC's Avatar
Although I've never been able to test it when I had an OD tranny, I've heard that when in "third", the tranny will shift with slightly higher line pressures than if it upshifts when in "OD". The higher line pressure will give a slightly firmer shift.
Old Jul 16, 2004 | 09:50 PM
LS1_03's Avatar
The only thing I keep it in 3rd for is to slow down after the 1/4 mile.
Old Jul 26, 2004 | 10:37 PM
MarkyMark's Avatar
Re: overdrive or 3rd?
Ive always used overdrive......it didnt shift into 3rd once when I had it in 3rd, so ever since I have used overdrive and have had no problems.
Old Jul 26, 2004 | 11:13 PM
Capn Pete's Avatar
What?! Has this / does this ever happen on the street, or only at the track? With 2.73's, you should be crossing the line right near the top of 2nd gear, so if you let off once you cross the line, you might not have noticed the tranny shift to 3rd.....especially not before you crossed the line.
Otherwise, there's something wrong, 'cause I drive with the shifter in 3rd all the time, and it will always shift to 3rd gear no problem as it should.....if it doesn't, then there's a problem somewhere!
Old Jul 27, 2004 | 11:40 AM
MarkyMark's Avatar
It was at the track and my car definately shifts to 3rd before the line......about 30 feet in front or so. It probably wouldnt happen again, but when it happened it just hit the rev limiter and didnt shift, so it was probably just a messed up one time only thing......but I'm happy with using overdrive and the car is running stronger than ever.
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 10:09 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
Girrrrl
Aug 20, 2015 09:26 AM
