need some setup advice please
Old Jun 15, 2004 | 07:36 PM
94-3.4's Avatar
Question need some setup advice please
So far the car is doing pretty good but I feel I am missing something. I raced yesterday in Douglas Wyoming and ran 13.7's but no matter what I do my 60's won't go below 2.0. When I drop the air pressure to 15 or below my ET goes up to 13.8/9. I ran the 13.7 on 18psi. It feels like it bogs when I launch with a lower tire pressure. I sure would like some advice on anything I can do (besides gears) to make this thing come out of the hole harder. Here is the setup:
lt1 w/ full bolt ons, hotcam kit, long tubes, etc etc
built 4l60e w/ 2800 stall 12" yank converter
323 gears
26" et streets
spohn lca's
bilstein shocks
v6 rear springs
3500lb car weight with me in it
Thanks guys!
Old Jun 16, 2004 | 03:25 AM
AL SS590 M6's Avatar
Moderator
I hate to say this but it's got to be more gear or more converter.
No free lunch.
It's bogging on a dead hook because the converter stalls well below the torque peak of the Hot cam.
Old Jun 21, 2004 | 08:21 AM
JIMS1999CONVZ28's Avatar
I agree
I agree.
3.73 gears and you will love the way the car responds.
I would do that first.
Then as AL SS590 M6 said do the converter...send it back to Mike and make it a 3500. It will take you a day and a half to adjust to it but then it will seem normal.
Pump you font tires up to 45 psi for less rolling resistance.
Remove the front sway bar for the drag strip, this will give you a better weight transfer.
If you really want to see the et go down, take a day and remove as much weight off the car as possible, seats, floor mats, etc and then see what it does, but make sure the baro and temps are about the same as the previous runs.
Old Jun 21, 2004 | 02:16 PM
Poik's Avatar
Even with a 2.0 60ft, how are you only going 13.7?
detroitmuscle
Jul 31, 2015 04:21 AM
realistyc
Jul 28, 2015 07:32 PM
ricks95TA
Jul 22, 2015 10:15 PM
dolfan324
Jul 17, 2015 10:34 PM
GT what?
Jul 14, 2015 10:17 PM
