need gears
Old Aug 20, 2007 | 01:45 AM
steve87iroc's Avatar
need gears
i need a new set of gears for my camaro i think i have some 2.73 and there killing me. i went to the track the other day and didnt do so well my 60" suck 2.15. i can acually go threw the finish at 6200rpm in second. the trans shifted by itself to second at 5000rpm but the other day i put some lighter weights in the trans govoner and took it out on the road and it shifted at 6600rpm and it was still pulling so i got the set up havent had it to the track yet. the fastest time i pulled of was 13.75 at 104.65mph how much more do you think i can get out of it from the shift point i have made. also i have 26" tall tires do you think i should go for 4.11 or 4.56. this is a race only car. looking to get in the 12's thanks
1987 iroc camaro gutted, 4" harwood cowl lift off, lakewood 90/10 struts lakewood 50/50 shocks, battery relocated to rear, b@m pro stick shifter, weld pro stars 15x6 in front 15x8 in rear, hoosier quick time pro 26/11.5/15,
355ci
dart iron eagle 215cc platinum heads with 64 cc chambers with guide plates, isky 507/507 lift 247/247
.50 lift with 108 lsa, victor jr intake ,holley 650dp choke horn milled, 1.5 roller rockers, moroso tall valve covers, hyper flat top pistons with 4 valve relief, stock rods, eagle crank, 1 5/8 longtube headers , turbo 400 trans with b@m shift kit and unknown 3500 stall
Old Aug 20, 2007 | 07:47 AM
AL SS590 M6's Avatar
Moderator
4.10s with the 26''ers will work if you can pull 6400 thru the traps. Unless your converter is real loose at high rpms.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
