looped rack
Old Dec 23, 2004 | 10:41 PM
LT1 Bunny's Avatar
looped rack
I was wondering if anyone has pictures of a looped power steering rack or could explain how they did it...im freakin confused on this one!! Thnaks guys! Im tired of all this power steering fluid flying everywhere.
Old Dec 24, 2004 | 09:48 AM
LT1 Bunny's Avatar
Re: looped rack
anyone??? i did do a search and i believe chevy guy had pictures of a looped rack but the links dont work anymore.
Old Dec 24, 2004 | 01:52 PM
mongse_1's Avatar
Re: looped rack
Very easy. You have two ports on your power rack (different size too IIRC). Make sure you have some fluid still in the rack and run a high-pressure hose from one port to the other. You're basically recirculating fluid through that hose rather than running it up to the pump and back. This isn't the easiest thing to turn (my Pinto-style rack is MUCH easier to turn because of the gearing), but you free up weight with the power steering pump, resevoir and fluid all gone. Just looping the rack and not removing this stuff is pointless.
Old Dec 24, 2004 | 03:36 PM
LT1 Bunny's Avatar
Re: looped rack
sweet...well for me it isnt really that pointless because the power steering fluid spits EVERYWHERE! I'm getting a rack at a later date and I really dont feel like spending 600 dollars on a manual from madman. I'm still removing the pump of course, lines, and res.
I'll have to check it out sometime sunday and see what your talking about. Think the hardest part that I didnt understand is leaving fluid in the rack. Fill it as much as it can hold right? Thanks alot bud!
Old Dec 24, 2004 | 10:05 PM
mongse_1's Avatar
Re: looped rack
Just leave some in there. Mine just had whatever was left over when I pulled the power steering off.
Old Dec 28, 2004 | 01:07 PM
Pro Stock John's Avatar
Re: looped rack
Madman rack drives great, my old looped rack was hard to turn when rolling slow, I was doing 6 pt turns to get into my garage.
Old Dec 30, 2004 | 05:59 PM
LT1 Bunny's Avatar
Re: looped rack
thanks a lot for your help. progress is going very slow...after 3 jaw pullers to get the balancer i now have to find some long bolts to tae the hub off. i found out in the haynes and chiltons manuals that the bolt size is 5/16. yeah right! the bolts were actually 7/16 - 14 thread. so now i have to wait till tomorrow tilli get three of the 7/16ths size bolts slooooooooow progress so far.
Old Jan 2, 2005 | 08:16 AM
Projectz28's Avatar
Moderator
Re: looped rack
wouldnt it be easier to just take the fluid out? I just took all the lines, pump and res off my car. I put a bucket under the ports and a piece of cardboard in front. Then I just turned it lock to lock several times and pushed all the fluid out. Plugged the holes and forget about it. Now I havent driven it this way but it is a track only car so I am not too worrried about making turns. Its still sitting up on stands right now and probably will be untill spring, but with the fluid in there it was much harder to turn. I mean why push the fluid around if you dont have to... Take it out and that just that nuch less work for your arms.
Old Jan 2, 2005 | 07:37 PM
LT1 Bunny's Avatar
Re: looped rack
im not too sure on this but i think the rack will be ruined if it does not have any fluid in there...just an assumption
Old Jan 3, 2005 | 01:02 PM
mongse_1's Avatar
Re: looped rack
A little fluid isn't going to hurt anything. I turned my wheels once each way w/ the ports open to get some of the fluid out, then capped them off.
Old Jan 5, 2005 | 11:29 AM
LT1 Bunny's Avatar
Re: looped rack
what did u use to cap them off?? i was just going to crimp them shut.
Old Jan 5, 2005 | 03:45 PM
mongse_1's Avatar
Re: looped rack
Regular metric bolts from the local store.
Old Jan 10, 2005 | 03:58 PM
chpmnsws6's Avatar
Re: looped rack
16mm and 18mm if i'm not mistaken
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
Boss002
Jul 9, 2015 03:33 PM
