looped rack
looped rack
I was wondering if anyone has pictures of a looped power steering rack or could explain how they did it...im freakin confused on this one!! Thnaks guys! Im tired of all this power steering fluid flying everywhere.
Re: looped rack
Very easy. You have two ports on your power rack (different size too IIRC). Make sure you have some fluid still in the rack and run a high-pressure hose from one port to the other. You're basically recirculating fluid through that hose rather than running it up to the pump and back. This isn't the easiest thing to turn (my Pinto-style rack is MUCH easier to turn because of the gearing), but you free up weight with the power steering pump, resevoir and fluid all gone. Just looping the rack and not removing this stuff is pointless.
Re: looped rack
sweet...well for me it isnt really that pointless because the power steering fluid spits EVERYWHERE! I'm getting a rack at a later date and I really dont feel like spending 600 dollars on a manual from madman. I'm still removing the pump of course, lines, and res.
I'll have to check it out sometime sunday and see what your talking about. Think the hardest part that I didnt understand is leaving fluid in the rack. Fill it as much as it can hold right? Thanks alot bud!
Re: looped rack
thanks a lot for your help. progress is going very slow...after 3 jaw pullers to get the balancer i now have to find some long bolts to tae the hub off. i found out in the haynes and chiltons manuals that the bolt size is 5/16. yeah right! the bolts were actually 7/16 - 14 thread. so now i have to wait till tomorrow tilli get three of the 7/16ths size bolts
slooooooooow progress so far.
Re: looped rack
wouldnt it be easier to just take the fluid out? I just took all the lines, pump and res off my car. I put a bucket under the ports and a piece of cardboard in front. Then I just turned it lock to lock several times and pushed all the fluid out. Plugged the holes and forget about it. Now I havent driven it this way but it is a track only car so I am not too worrried about making turns. Its still sitting up on stands right now and probably will be untill spring, but with the fluid in there it was much harder to turn. I mean why push the fluid around if you dont have to... Take it out and that just that nuch less work for your arms.
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
