LCA relocation brackets?
Old Aug 14, 2007 | 11:57 AM
Vicious95Z28's Avatar
Are there any real diffrences between these from BMR or UMI? How many of you guys noticed a nice difference?
Old Aug 14, 2007 | 01:46 PM
Gtpguy's Avatar
I bought a set of the Spohn LCARs. Traction is much better, but it really kills the fun factor. But traction wins races, not wheel spin. For $60, they are a huge bargain. Get them and you won't be dissapointed. Install was like 5 minutes each side.
Old Aug 14, 2007 | 09:01 PM
The Engineer's Avatar
Relocation brackets are one of the best and cheapest suspension mods you can do. They completely reverse the rear suspension geometry (raise versus squat).
WD
Old Aug 14, 2007 | 11:20 PM
exgmguy's Avatar
A good idea even on a light bolt-on car?
Old Aug 15, 2007 | 07:49 AM
Yeah, right now the axle side of the rear control arm is higher than the body side. Not good. Wouldn't that completely eliminate instant center? With it like this the control arms and the T/A don't even run parralel, they run away from each other, does this make sense?
Old Aug 15, 2007 | 08:20 AM
AL SS590 M6's Avatar
Moderator
It makes your instant center behind the car. Not good at all.
Old Aug 15, 2007 | 08:22 AM
Moderator
Yep, relos with some poly bushing in my home boxed LCAs got me down to the low 1.6- high 1.5 sixty foots before adding enough power to make the set up unreliable.
Old Aug 15, 2007 | 02:36 PM
I'm getting the Bolt ins from UMI shortly. I'm itching to do it but I've got to pay down some other things to keep the wifey happy
Old Aug 18, 2007 | 11:58 AM
CamaroRacing12's Avatar
where are the LCa relocation brackets located on ur car? how do u install??? im so lost with suspension
Old Aug 18, 2007 | 12:25 PM
The LCA relocation bracket welds or bolts to the stock LCA mount on your rear axle assembly. It allows you to lower the axle end of the LCA relative to the body end.
The photo posted above shows the bracket. This is the Spohn version (black rectangular bracket that the end of the LCA is bolted to):
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
War Engine
Sep 18, 2015 07:28 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
