Launching a non-posi car
Old Oct 25, 2002 | 03:52 PM
Chuck!'s Avatar
Any suggestions as to how to go about launching one wheel peel? 2.412 60's are killin me lol!
Old Oct 25, 2002 | 04:05 PM
Joe Brodman's Avatar
GP Moderator
I have a buddy who was pulling high 1.6 to low 1.7 60's on an open rear w/ 275/60/15 BFG DR's.
If I recall right, he was doing his inital smokey burnout, followed by 3-4 almost dry hops; basically, getting the car to get the other tire to spin instead. His whole goal was to get one tire to spin, then the other, then the other, etc.
Mind you, this was on an 83Z with stock 3.73's, budget built solid roller 355 shifting at 8000, with a manual valve body TH-350 running upper 11's, skinnies, stock front suspension and minor rear suspension mods. Worked for him, though he is also a pretty good driver. (he is now running a 12-bolt and QTP's)
Old Oct 25, 2002 | 08:01 PM
Chuck!'s Avatar
Well lets assume the car is a 305 with 2.73 gears and 245/50/16 Kuhmos... 700R4 running ohhh mid 15s
Old Oct 28, 2002 | 06:25 PM
AutoRoc's Avatar
ytjrt byj
1. Step on the throttle as HARD as you can!! Don't let up if it spins, trust me...While accelerating as fast as possible, call JEGS!! and order a ****ing Auburn Pro Posi lol
Old Nov 6, 2002 | 03:05 PM
walrus108's Avatar
how to get one wheel drive to launch
Get and airbag in the passenger rear coil spring. Add air and try to spin the tires. When you pre-load the pass rear enough to equalize pressure when you launch, you will spin both tires equally. This is how they did it before posi's were common.
Jazsun
Dec 29, 2014 12:14 PM
mark0006
Dec 25, 2014 09:50 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
