Hooking...........!!!!!!!!!!
Old Aug 18, 2002 | 04:57 PM
Pewter99_Trans's Avatar
Post Hooking...........!!!!!!!!!!
I am getting ready to run a stock 01 lightning in my town and I cant get my car to hook to save my life! I have a 99 trans am,a4,3.23's, with a lid and K&N. I will spin from idle all the way through 1st with a half throttle punch then flooring it. I have dropped my sotck rubber down to about 26 psi. Any help on getting traction and how so tips on just how much gas to give it off the line would help me alot!
Old Aug 18, 2002 | 05:34 PM
chevyguy3's Avatar
Post
get drag radials
Old Aug 18, 2002 | 06:39 PM
Post
Thats not a option living with my parents.......dont really approve of street racing when insurance is about $5000 a year. Know what I mean. I cant affoard to get caught either paying as much I can for insurance. I thought about turning on my traction conrol but I know thats a no no. Also filled my gas tank up all the way.
Old Aug 18, 2002 | 07:39 PM
AutoRoc's Avatar
Lightbulb
So you want traction/suspension modifications that can be hidden? WTF??
You need a solution and the cheapest one is to get Drag Radials. If that's not an option, then why did you make a post in the first place? IT IS AN OPTION!!
Old Aug 18, 2002 | 08:11 PM
Post
If you hadnt caught on fully I live at home until I graduate soooooooooo I cant have my car in the shop getting crap donne to it. I mean my car being gone wouldnt make my dad suspicious or anything.
Old Aug 18, 2002 | 08:43 PM
kcsoz20's Avatar
Exclamation
The Lightning will prolly be running street tires too.
I can launch on my street tires with just a minimal amount of spin and roll into the throttle.
This takes practice. Lower your tire pressure and practice launching. Brake stall the car. When ready to go basically let off on the brake and roll the throttle up.
Again this will take practice to get the feel of your car. If the lightning has street tires and he does not know how to do this he will just spin and you will slowly pull out from him into WOT. Just don't panic and go into WOT thorttle too fast. Especially if you see him creeping ahead of you as he is probably throttling too.
I know, I have had a friend try to race me on the street, (I don't street race) He had a M6 he dropped the clutch trying to get a launch. I teased him with a little throttle blip pulled out and watched him fishtailing all over the place trying to get traction while I just rolled away.
Be careful and don't kill yourself or worse yet hurt someone else! You think insurance is expensive now.
My best advice is to save it for the track.
Ken
95 Z28, BBK 52 mm throttle body, ported MAF ends, K&N CAI, ASP Pulleys, 160 thermostat, PCM by WWW.PCMFORLESS, LT4 KM, Heads by WWW.flow-technics.com, 2.055 int/1.57 exh. valves, 1.6 RR's, CC XE 230/236 544/556 112 LSA, Comp "R" lifters, Comp Magnum pushrods, FMS 24# SVO injectors, Meziere WP, Jet Hot coated Hooker LT's, Flowmaster cat back exh., PI Vig 2800-3000 TC, Strange 3.73 gears. Dyno numbers to come soon.
60' 1.690
1/8 7.674
MPH trap broke
1/4 12.059
MPH 113.00
My car www.teamnwfbody.org/members/mcdonald.htm
Old Aug 18, 2002 | 10:11 PM
NJ SPEEDER's Avatar
Post
quick and easy half a$$ed solution is to drop teh front sway bar adn raise your front air pressure a bit.
or you coudl just go to the track where tehy have sticky ground for you to play on and you don't have to worry about your insurnace or getting caught by the cops.
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
2nd Annual East Coast F-Body Nationals
July 20,2002
www.geocities.com/njspeeder
My MAFB.ORG Home Page
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Aug 18, 2002 | 10:55 PM
AutoRoc's Avatar
Post
Having tires(sticky drag radials) installed on a car isn't like having a car in a performance shop..geez. My Nitto drags were installed in under a half hour if I remember correctly.
Relocation brackets too...Have a set welded onto your rear axle and it will relocate the lower control arms to a better more aggressive angle for more traction. At like $65 for a set+ welding cost, it is cheap traction. Goodluck
Old Aug 19, 2002 | 07:24 AM
TedH's Avatar
Post
Get some drag radials. They look like regular tires.
More importantly, go to the track. That way you don't need to worry about getting busted. This is the drag racing forum, not the "how can I be stupid and street race forum".
Drag racing is a generally safe motorsport, especially with cars that are essentially street legal. Perhaps if you take the time to educate your parents about drag racing they might not be so uptight.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
Old Aug 19, 2002 | 12:42 PM
Ken95Z28's Avatar
Post
Ditto on that tnthub!
If I was you I would invite my parents out to the track and see what they think.
Keep it at the track and off the street!
1995 Z28 A4 3.42 Best ET(12.205@109.50) LT4 Hot Cam, 1.6RR's, K&N FIPK, 85mm MAF, Mac Header & Y-pipe, Flowmaster Exhaust, CutOut, Yank ST3500, TransGo Shift Kit, LT1 ScanMaster, CSI WP, M/T ET Streets, 6-point Wolfecraft and Ed Wright Programming
Ken's 1995 Z28
F-Body Fastest List
"Never be afraid to try something new. Remember that amateurs built the ark. Professionals built the Titanic."
Old Aug 19, 2002 | 02:22 PM
kazman's Avatar
Post
Another vote for drag radials and keep it to the track.
'95 FORMULA Blue-Green Chameleon, M6, Suncoast WS6 ram air hood, K&N, Granetilli MAS, BMR supension, Hypertech program & 160 stat, LT4 knock module, Hurst shifter, Star Stage II clutch, Borla Cat Back, Goodrich Drag Radials, Moser 12-bolt 4.11 rear, 13.18@102 1.90 60' on the breaks, last run of the 2001 season
Old Aug 19, 2002 | 02:55 PM
Projectz28's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by kazman:
</font>
what he said .
Brian
96 Red z28, A4, Flowmaster, SLP CAI, AFPR, B&M transpack & cooler, LT4 KM, 3.73's, T/A girdle, LS1 driveshaft, cc305, Crane 1.6's, MSD 6AL, Meziere, ST3500, JetHot/Hooker LT's
The Project!!!
Best ET: 11.91 Best MPH: 113.54 Best 60': 1.59
327RWHP/380RWTQ
East Coast F-body Nats
It's god's responsibility to forgive Bin Laden, it's our responsibility to arrange the meeting...
-United States Marines
Old Aug 20, 2002 | 10:41 PM
CRZYTRN-92Z28's Avatar
Unhappy
what if you dont have a track...
Old Aug 21, 2002 | 08:23 AM
kazman's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by CRZYTRN-92Z28:
</font>
This may help locate a track.
http://drag.race-cars.com/utility/circuits.htm
Old Aug 21, 2002 | 08:44 AM
red's Avatar
red
Post
If you don't want to change the car your only option is to change the driver.
In other words, learn to drive.
Now that we have gone down that road. This should be the first place you start. Too many people throw money at a car to make up for the drivers short commings.
Learn to roll in to the throttle and controll wheel spin.
95Z M6
383
and a few other mods
