how well do 245 bfg dr's hook?
Old Jan 4, 2004 | 07:53 PM
zx1216's Avatar
what kind of 60' times are you guys pulling with stock sized 245/50/16 bfg drag radials? How much power are you putting down?
Old Jan 4, 2004 | 08:12 PM
Steve Y's Avatar
Moot point. BFG does not make a drag radial in that size. The closest to that size is a 255/50R16. My buddy pulled a 2.0 60' with a fairly worn set on a '91 5.0. I will tell you how they hook in a couple months with my car.
Old Jan 5, 2004 | 06:08 AM
Raptor1's Avatar
"Steve Y" is correct. The size you probably mean is 255/50/16, not 245/50/16. Not much difference size-wise though between the two.
I'm on my 4th set. You can check my sig for 60' times. The last dyno pull showed 335 RWHP and 345 RWTQ. And that was with a bad Opti.
I generally run ~18 psi in them and do a hot burnout.
Old Jan 5, 2004 | 07:51 PM
zx1216's Avatar
oh, yea i ment 255, but from your 60' it looks like they hoow fairly well
Old Jan 6, 2004 | 07:51 AM
Raptor1's Avatar
Considering I only have a 2800 converter and my porky race weight I'd say, Yeah, they hook pretty well
Old Jan 6, 2004 | 05:37 PM
GreenbeanZ28's Avatar
I 1.74'd on them, stock suspension and bolt ons, 6 speed.
Old Jan 7, 2004 | 12:18 PM
kevkop94TA's Avatar
I did pretty well on them, time in the sig, raceweight was 38XX with only a 2600 converter. Theyre pretty damn good.
Old Jan 10, 2004 | 08:52 AM
CANTONRACER's Avatar
1.63
Stock rims, KBDD, IRS LCA, 2000 rpm launch on motor.
Old Jan 13, 2004 | 01:05 PM
TheZ's Avatar
GreenbeanZ28 I 1.74'd on them, stock suspension and bolt ons, 6 speed
What kind of rpms are you leaving the line at?
Old Jan 13, 2004 | 02:34 PM
Antz97ZNJ's Avatar
They hook good (on a well prepped track), they more of a "drag racing" tire as opposed to the Nittos
Old Jan 16, 2004 | 10:20 PM
Dragon Racing's Avatar
60' times and mods in sig. I usually adjust tire pressure from 16-18 psi depending on how good the track is hooking.
Old Jan 17, 2004 | 03:13 PM
Around 5200-5300.
Old Jan 17, 2004 | 10:56 PM
96LT14u2Nv's Avatar
i tried running on these tires for a while and could only pull low 1.9'-2.0's on them. swapped to 26x11.5 ET streets and went low 1.7's!!!! i say screw dR's unless u are using them on the street
Old Jan 18, 2004 | 06:22 PM
simple's Avatar
Originally posted by GreenbeanZ28
Around 5200-5300.
Russ, is that a full on clutch dump or are your riding it out, if riding it out about when does full engagement come in?
Steve
Old Jan 19, 2004 | 04:08 AM
chpmnsws6's Avatar
i swear i found my next set of tires after hearing 1.63's on em! i won't hafta heat em up at all and that will save the tread wear
may all of you prayer for the rear end!
