how well do 245 bfg dr's hook?
Old Jan 19, 2004 | 07:07 AM
  #16
Raptor1's Avatar
Originally posted by 96LT14u2Nv
i tried running on these tires for a while and could only pull low 1.9'-2.0's on them. swapped to 26x11.5 ET streets and went low 1.7's!!!! i say screw dR's unless u are using them on the street
Hmm...you seem to be the only one who has responded so far that has/had a problem with them hooking
Old Jan 20, 2004 | 08:19 PM
  #17
kevkop94TA's Avatar
Or if you'd like your 10 bolt to live.
If your dead hooking with drag radials, no pin at all, then slicks won't improve anything, you're already getting a perfect launch.
Old Jan 20, 2004 | 09:28 PM
  #18
CANTONRACER's Avatar
If you cut the same 60' with a slicks or an E.T. street as BFG DR's, you will probably have a slower ET and MPH due to the side wall eating up some rwhp.
Old Jan 21, 2004 | 05:26 PM
  #19
GreenbeanZ28's Avatar
Originally posted by simple
Russ, is that a full on clutch dump or are your riding it out, if riding it out about when does full engagement come in?
Steve
Thats dumping it.
Old Jan 23, 2004 | 07:34 AM
  #20
simple's Avatar
what kind of burnout would be recommended with these tires?
huge smokes show style burnouts or just get them smoking but not too thick?
Old Jan 23, 2004 | 07:58 AM
  #21
Raptor1's Avatar
Depends on how much HP you've got BFG recommends heating them just enough to get a little smoke coming off of them. That's never worked for me. I use 18-20 PSIG and do a HOT burnout - yeah, lots of smoke. That's how they work best for me.
Old Jan 23, 2004 | 01:00 PM
  #22
simple's Avatar
Raptor, your 60ft listed in your sig, is that on BFG's, if so what size?
Old Jan 23, 2004 | 01:23 PM
  #23
Raptor1's Avatar
Yes, BFG DR's, 255/50-16 - the only 16" DR that BFG makes. I should see some low 1.6 short times this spring on a well prepped track.
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
canuck94z28
Aug 19, 2015 05:50 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 9, 2015 03:33 PM
