how well do 245 bfg dr's hook?
Moot point. BFG does not make a drag radial in that size. The closest to that size is a 255/50R16. My buddy pulled a 2.0 60' with a fairly worn set on a '91 5.0. I will tell you how they hook in a couple months with my car.
"Steve Y" is correct. The size you probably mean is 255/50/16, not 245/50/16. Not much difference size-wise though between the two.
I'm on my 4th set. You can check my sig for 60' times. The last dyno pull showed 335 RWHP and 345 RWTQ. And that was with a bad Opti.
I generally run ~18 psi in them and do a hot burnout.
Originally posted by zx1216
oh, yea i ment 255, but from your 60' it looks like they hoow fairly well
