How much gain from 4.11's?
Old Apr 21, 2004 | 08:09 AM
importeater's Avatar
Well the 4.11's are being installed as we speek. What kind of gains should I see from them? Will my MPH drop? My best is in my sig with the stock 3.42's.
TIA
Craig
Old Apr 22, 2004 | 08:01 AM
Red95M6Z28's Avatar
13.64@105.1mph // Just a guess.
Old Apr 25, 2004 | 06:29 PM
D James's Avatar
I gained a consistant 2 tenths on average. I imagine 4 tenths could be had. It makes a pretty big difference in performance. Its real hard to hook up, although I found my 60 ft improved slightly-which might be attributed to me getting better at launching-not really sure. My MPH dropped 2 but then again that day everyone was down a little because of the crappy weather.
Old Apr 26, 2004 | 12:43 PM
Steve94Z28's Avatar
How come I see 4.10's and 4.11's in these peoples Sigs? I mean which gear fits into our stock 10 bolts? (LT1)
Old Apr 26, 2004 | 02:54 PM
GREGG 97Z's Avatar
I gained a little over 2/10's and 2-3mph when I went from 3.42's to 4.11's. Plus I became addicted for a while to doing 0-60 runs after installing them
Ratio wise they are basically the same, it's just the difference in the teeth used on the ring and pinion gears:
4.10's = 41 teeth on the ring gear and 10 on the pinion (41/10=4.10)
4.11's = 37 ring / 9 pinion
(37/9=4.11)
4.11's gears are slightly stronger from what I hear since they have fewer teeth and those teeth are larger than those on the 4.10's.
Old Apr 26, 2004 | 11:55 PM
Red96Lt1's Avatar
yeah, what he said. I would go with 4:11's
Nutty's96
Dec 21, 2015 06:25 AM
colts0455
Sep 22, 2015 02:03 PM
colts0455
Sep 2, 2015 12:41 PM
ddr698
Jan 9, 2015 10:05 AM
amc91z
3rd Gen / L98 Engine Tech
Aug 4, 2002 05:16 PM
