HELP cant get car to hook
Old Jun 18, 2005 | 05:58 PM
  #16
Derrick Redd's Avatar
Re: HELP cant get car to hook
Originally Posted by buzz12586
I assume that was with an A4??
Your assumption is correct.
Old Jun 20, 2005 | 06:11 PM
  #17
veee8's Avatar
I just pulled a couple of 1.88 60 fts. with bald 295 F1 Supercars with an A4 and stock suspension. aired em down to about 26 psi.
Old Jun 22, 2005 | 01:18 PM
  #18
Tru2Chevy's Avatar
Originally Posted by nonojoe66
and i go to englishtown, so the track surface is probably better kept then many smaller tracks. guess we will see in 2 weeks when i go for another test and tune nite
Eh - E-town's prep depends largely on what night it is. I prefer Atco on Tuesday nights. They run Gamblers then, so prep is usually good. Plus it's cheaper than E-town, and you can get more runs in.
Play with your tire pressures, get em hot, and keep practicing.
- Justin
Old Jun 26, 2005 | 06:17 PM
  #19
pineapplesink6's Avatar
lol the 555r is a drag radial just like the M/T but it is a little more streetable, but i should still b able to pull 1.6 60 ft times on them. and for these tires the general consensus on this board seems to b 20-25psi for the street or else the tire will wear funny if u put more, and 18 on the track. the problem must be that i didnt heat them up enough, i didnt do very big burnouts because i didnt want to beat on the tires that much, and i guessed it would still hook ok, but i guess thats y i got drag radials and i might as well just go all out with them
1.6 60 foot times? i think you are dreaming my friend............
Old Jun 27, 2005 | 11:33 AM
  #20
Capt'n Two Rotors's Avatar
I ahve pulled as best of 1.74 60' with my nito's at 22 psi and no suspension mods at a crappy south alabama 1/8 mile track with no prep, 1.60 should be no problem with some suspenion work. It seems like the guy's running the mickeys are hooking better though.
Old Jun 27, 2005 | 11:45 AM
  #21
jsetzer's Avatar
I pulled several 2.1s and a 2.0 on crappy 16" sumitomos last weekend. Thats an m6, stock clutch, 4.10s in a 10bolt. I am just waiting to hear it go POP.
Old Jun 27, 2005 | 03:43 PM
  #22
WildThing94Z's Avatar
Leatherneck has pulled several 1.6's with the 245 Nitto's and a stock rear suspension in an A4 with a Vigilante stall and the hotcam . . . . so it can be done.
I'm looking to do the same, just have not hit the track yet.
Old Jun 27, 2005 | 05:02 PM
  #23
1.60's with stock suspension with only 245's........wow!
Old Jul 1, 2005 | 06:36 PM
  #24
1993CaMaRoZ28ofIdAhO's Avatar
The big thing for me was to get the tires moderatly hot. And that pulled my 60ft up nicely.
Old Jul 4, 2005 | 12:33 AM
  #25
nonojoe66's Avatar
yea 1.6 was a typo, i prolly ment like 1.7 or 1.8, but either way with the right set up and some luck 1.6 is possible.
Old Aug 19, 2005 | 05:53 PM
  #26
Cmr0z28's Avatar
Sounds like a track prep issue.
Old Aug 19, 2005 | 09:00 PM
  #27
IrocSS85's Avatar
I think sub 2.0 from a 13.8 sec. car is askin alot too much. maybe if you stick a stall conv. in there it'll get down there. but Id say 2.0-2.1 would be doin pretty good for your car.
when I had my drag radials on my Iroc, it was a 13.3 sec car. but it also had a 3500 stall in it at that point. it would pull mid 1.7's-l0w 1.8's consistently. I used about 22lbs pressure, held low gear for about 4-5 sec.s, then shifted into second gear and let out the brake while still accelerating. it'll start moving forward out of the box and once it leaves the box, you should feel them start to grab. maybe a couple feet out of the box and Id let off the gas and roll up to stage. mine hooked pretty descent doin this, I kept mine at 35 on the street.
BTW, I did some work to the Iroc to make it faster, but the stall conv. broke, so i had much more power, but a cheap torque conv. and I was running 12.6's with 1.9's sixty's was the best I could get the car to do w/o the stall conv..
good luck
Old Aug 21, 2005 | 01:24 PM
  #28
nonojoe66's Avatar
lol well i dont think its asking to much, this is a old thread, i went to the track since with them, my car was misfiring horribly but i still managed a 2.0 60ft on my last run (i only made 2), and i could have probably maxed out the stall and droped that by a tenth or 2. but because of the missfire i only ran a 14.2 on that run, so if a 2 second 60ft is possible on it when it runs 14.2 i think it wont be a problem when its runing rite. lol and dont forget that a 13.8 second car with a 2.3 60 ft is probably a sub 13.5 with a sub 2 sec 60.
mr28
Apr 20, 2016 05:44 PM
sdn1997rs
Dec 30, 2014 08:30 AM
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
