Have ? about lowered car
Old Nov 25, 2004 | 06:04 PM
BAD97SS's Avatar
Will this hurt your drag times. I'm looking to go back to stock cause when I bought the car it was lowered. The rear is hitting the bump stops in the rear when I lauch. Have any of you noticed your 1/4 mile times change when you went with this setup. Thanks John
Old Nov 25, 2004 | 07:27 PM
Capn Pete's Avatar
Re: Have ? about lowered car
I think as long as you run good, sticky tires, having a lowered car won't hurt you at the track. BUT, if you're having traction problems, then a lowered suspension isn't going to help, because you don't get the same amount of weight transfer as if the car was at factory ride height. If you like having the car lowered, leave it that way and just run DR's or ET Streets to compensate for traction (you may also want to get LCA relocation brackets, if you don't already have them installed.....they will help traction, especially since the car was lowered).
Old Nov 25, 2004 | 08:32 PM
Stephen 87 IROC's Avatar
Lowering the car changes the suspension geometry. You should have LCA relocation brackets to correct the angle of the LCA. LCA should be parallel to the ground or slightly down at the rear. When you lower the car, the LCA is lowered at the front. You should also have an adjustable torque arm to correct the pinion angle.
You can also install air bags into the rear springs and play with air pressure but I wouldn't suggest it until the suspension geometry is corrected first.
Old Nov 26, 2004 | 06:54 AM
TedH's Avatar
You question is in regards to you car which is already lowered, right? In general lowered cars are more difficult to hook up at the strip. Going back to stock, or even some drag springs and shocks sounds like a good idea.
Old Nov 26, 2004 | 08:26 AM
BLACKBIRD8200's Avatar
My car is lowered 1-1/2" traction sucked really bad wheel hop was very bad!
i put BMR sub-frames,lower control arms,and relocation brakets. it's like day and night now and my car is a convert too. went to the track and ran 13.5-13.4-13.3.it just kept getting faster i stopped at 13.3 i was happy my car hooks great now!
Old Dec 6, 2004 | 12:16 PM
rskrause's Avatar
Moderator
I ran 60' times in the high 1.5sec range with Eibach springs, Spohn torque arm, and LCA relo brackets on 10" ET Streets.
Rich
Old Dec 11, 2004 | 02:50 PM
redcamaroz28's Avatar
What I do is just swap in the stock rear springs every time I go to the track.
Noenav
Mar 1, 2019 07:38 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
