Good 6 Speed launch
Old Jul 5, 2009 | 01:17 AM
94 Assault z28's Avatar
Good 6 Speed launch
im looking for a good hard 6 speed drag launch tech., its hard for me to get up and hook i have rear drag launch springs and a short throw shifter with 3.73 gears with mickey thompson ET drag radials at 15psi. stock LT1 camaro . please help me!
Old Jul 5, 2009 | 07:22 PM
96SSIndeed's Avatar
i launched mine at about 3000-3500rpms and it hooked good on nitto555's. just some input.
Old Jul 6, 2009 | 04:37 AM
jonesy's Avatar
get some relocation brackets, LCA's, sub frame connectors, tunnel mount torque arm, adjustable shocks, and last but not least start saving for A REAREND
Old Jul 6, 2009 | 11:10 AM
96SSIndeed's Avatar
listen to this guy. the 6 speed is the reason i have a 9"
Old Jul 6, 2009 | 11:59 AM
slomarao's Avatar
slip the clutch between 2-4k if you dont want to break anything. If you have the guts and a trailer dump it from 4-5k. Do a search you will find tons of launching techniques.
Old Jul 6, 2009 | 02:01 PM
when i launch it around 3500 it bangs into gear but it allmost stalls out. i just slip my foot side ways off the pedal so the clutch dose the work thats when it happens . any thoughts on that?
Old Jul 6, 2009 | 02:31 PM
Paul94Z28's Avatar
4000 Launch
I hook well with drag radials in the 3500 range. I launched hard at 4000, stuck well, and shredded my posi.
Start saving for a rear now, you are gonna need it.
Old Jul 6, 2009 | 05:02 PM
slomarao's Avatar
your bogging it. Keep playing around. that twig 10 bolt will be gone soon....
Old Jul 6, 2009 | 10:34 PM
nd4spd200's Avatar
The best advice anyone on here can give you is practice practice practice. The only thing that will make you better is trying differn't things. Try something differnt every time till you get it right.
Old Jul 15, 2009 | 01:45 PM
sc68z28's Avatar
To me a "good hard 6 speed drag launch" would be dumping the clutch at whatever RPM you make peek HP, that's what I do, 6500+ rpm .
Mine is only a 5 speed, but I use all 5 gears at the track. 1st gear is important, mine is 3.11:1 with a rear gear of 4.11:1. Or a total 1st gear of (3.11 X 4.11=) 12.78:1 . Some say that even lower 1st gear is better 14, to 16:1.
Biggest thing is the clutch will need to slip at launch and after each shift.
I'm still working on my clutch tune, only a 1.32 60 foot so far.
Here is a 60' test vid http://www.youtube.com/watch?v=x3UZW6smFtw
I should be in the high 1.2x 60 foots.
---Bill.
Old Jul 19, 2009 | 01:00 AM
Bayer-Z28's Avatar
Or until the 10b gives out.. Funny, but not..
I need a 9"...
Old Jul 27, 2009 | 05:36 PM
95Bird's Avatar
first and formost ...get a good rear end, then a full suspension, good shocks, good torque arm, and a drag sway bar. Get some slicks and a 2 step and you can launch the hell out of it. You will find any weak links in the drivetrain of your car, like imput shafts, outputshafts, clutches, driveshafts etc. But..you will be able to leave hard. My best 60' so far is 1.42...its a blast, I highly recommend it.
DirtyDaveW
Dec 1, 2016 05:37 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
mark0006
Dec 25, 2014 09:50 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
