Front studs, How long
Old Feb 8, 2008 | 09:38 PM
walt355's Avatar
For welds and to be legal? Thanks
Old Feb 9, 2008 | 12:07 AM
6089wally's Avatar
RULE BOOK STATES "The thread engagement on all wheel studs to the lug nut must be equivalent to or greater than the diameter of the stud"(example: a 7/16 stud must be engaged through the threads in the hex portion of the lug a minimum of 7/16-inch.) pg 84 in the 2008 NHRA rule book. In other words, make sure the studs stick out of the wheel when placed on hub.
Old Feb 9, 2008 | 12:32 AM
Stephen 87 IROC's Avatar
In simplest terms, the stud must extent past the surface of the rim equal to the thickness of the stud.
If you're using 7/16" studs, they must extend at least 7/16" past the rim (and washer). For Weld Prostar and Draglite rims, you'll need a stud about 2-1/2" long.
Old Feb 9, 2008 | 02:40 PM
There's info on the Welds, stud length, etc., in the FAQ, stickied at the top of the Wheels and Tires forum topic listing page.
Old Feb 9, 2008 | 10:08 PM
walt355's Avatar
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
