First time results
Old Aug 27, 2004 | 10:02 PM
My00Camaroz28's Avatar
First time results
Well to say the least im pretty disappointed. I know this was my first time racing my car at the track and that im only 17, but when I can only pull a best of 13.8 at 103 that gets me pretty mad. On that run as the other ones I couldent get my 60' to go below 2.239. I also think that maybe my gearing isnt as I thought with the 3.23's. Also i'd like to add that my tank was FULL and I had 20 in each rear tire (street tires). Can someone please help me out for the next time I go out there. Do my times seem that bad?
Old Aug 27, 2004 | 10:24 PM
Stephen 87 IROC's Avatar
Re: First time results
Fill the tires up to 32 psi and start from there. Street tires are not designed for low air pressure. The stiff radial sidewalls won't roll over and they force the center of the tire off the ground. Many times street tires get their best traction in the 30 - 35 psi range.
Old Aug 27, 2004 | 10:40 PM
IllusionalTA's Avatar
I woudn't say you did all that bad.. A buddy of mine w/ a 02 z28 was pulling mid 14's his first time out.. Needless to say the car now goes bottom 12's.. but we all have to start somewhere.. Do like steve said and play w/ it or get a stickier radial and watch your time's drop.. you got yourself a low 13. sec. car if you drop to a 1.960ft that and some better air and you could possibly tap the 12's ... OH and go w/ less gas next time as well
Old Aug 27, 2004 | 11:09 PM
toneloc12345's Avatar
Your full tank of gas wasn't really hurting you much at all, probably not even a .1. 20's on a camaro doesn't help the 1/4 times though
TONY
Old Aug 27, 2004 | 11:33 PM
i think he was talking about 20 psi.. a gallon of water is approx 5lbs or so.. thats about 60lbs.. which is equiv to .05 or so.. Every lil bit help's here and there..
Old Sep 3, 2004 | 04:24 PM
Antz97ZNJ's Avatar
1st time I ever ran my stock 97 273 car i ran a 14.9
Old Sep 3, 2004 | 05:02 PM
97s10ondubs's Avatar
i think the full tank of gas helps traction, when i went on street tires i pulled my best 60' after i went to the gas station and came back
alex5366
Feb 17, 2015 08:12 PM
jb4xx
Feb 2, 2015 10:00 PM
edman
Jan 22, 2015 02:45 PM
Doug Harden
55
May 15, 2003 12:08 PM
guionM
28
Aug 19, 2002 05:02 PM
