Fastest 4L60E 10 Bolt car?
Old Sep 7, 2004 | 06:46 AM
  #31
Raptor1's Avatar
Re: Fastest 4L60E 10 Bolt car?
Originally Posted by Capn Pete
... I think for the number of BAD cases we hear about, we don't hear about all the GOOD examples of stock cars that stay together.
Naturally. People don't usually post saying how long their trans or rear has lasted. They post when they are pissed about something breaking
... I also daily-drive my car, and even MANUALLY SHIFT IT on occasion!! ...
Yeah, I forgot to mention that too - I used to manually down shift mine all the time and the transmission experts say that's the worst thing you can do to an auto.
Old Sep 7, 2004 | 08:47 PM
  #32
12SCNDZ's Avatar
OK...I gotta get in on this...Atleast from the 4L60E aspect First of all, I'm the one that built Dirks (RACINLT1)'s transmission. I had NO doubt it could carry him into the 10's EASY. The output shaft snapping was a fluke. As for later 4L60E's being stronger??? A '94 60E is just as strong as an '04 60E They did make improvements to help the low/rev clutches last longer in '97, but it wasn't a real big deal...I can modify older units to achieve the same results with a .035" drill bit.
4L65E??? Yes, just in trucks, but we can use all the parts in a 60E. They have 5 pinion planetaries The thing that made the 700/60E 4 pinion planetaries fail 80% of the time was the bearing in the planetary going bad. The 5 pinion uses the SAME bearings! There's a LONG story behind this, but to make it short, GM has ALOT of problems with the rear ring gears shattering in the 65E's because they're not hardened enough. The sun shell uses a bearing, instead of a thrust washer like 60E's. Less drag...I used this set up in my 700. 65E's also have hardened output shafts...Unfortunately, these weren't available yet when I built Dirks
The 700, 60E and the 65E all have a large number of interchangeable parts. I use some 700 and 65E parts in the racing 60E's I build, and I use some 60E and 65E parts in the racing 700's I build. Call it a mutt or a hybrid...LOL. I use the best parts that each has to offer.
As for my personal car? '93 Z with a 700 and a 10 bolt...I plan on taking them both in the 10's with me when I get this nitrous crap sorted out
Frank
Cahall Performance Transmissions
Old Apr 23, 2020 | 08:30 PM
  #33
Grease monkey's Avatar
Originally Posted by WS Sick
As long as you minimize the shock on them (auto tranny, good bias ply tires) you can help them out, They now make strong axels for them. I know a guy that has a 7.5 in his S-10 running 1.50s and 60s 60 footers, he added axels and a T/A diff cover with studd girdle and preload bolts. He's running GM 3.73 rear gears and an auburn Posi. (its about 7 or 8 years old now)
I am going this way with my 03 Sonoma and a 5.7l, with around 500hp at the fw.
Old Oct 10, 2024 | 09:18 AM
  #34
Originally Posted by lovemycar99
Hey Awesome achievements!1.44s is a great time!If you're planning to up jet to 300, that could really boost your results.Just make sure to tune the fuel mixture well as that’s key to getting max power!
Just curious….. are there many Camaros in Poland? Do you have one?
And, “OBDIICamaro” hasn’t returned to this site since April 2006.
Nightshade
Mar 23, 2009 01:45 PM
kline454
May 2, 2007 02:15 AM
SABLT194
Aug 10, 2006 06:36 AM
Fishv12
Jan 16, 2004 08:12 AM
TorchRedZ28
May 28, 2003 03:25 AM
