different classes
Old Aug 30, 2003 | 11:14 PM
zuluman13's Avatar
different classes
What class of drag racing would be best the only thing that i would imagine would work without an all out drag car is bracket racing but can manuals be good for bracket racing. What if i decided to build an all out drag car what would be a good class to start in(also the cheapest to be somewhat competitive)
Old Aug 31, 2003 | 08:31 AM
Stephen 87 IROC's Avatar
At least 90% of all drag racing is bracket racing. Even the Stock/SuperStock classes are bracket racing unless 2 cars in the same class are paired up against each other.
The cheapest class to run in is ET brackets. All the other fast classes are not cheap. Even Stock/SuperStock is not cheap. Comp Eliminator is probably one of the most expensive classes to run in.
Old Aug 31, 2003 | 08:42 AM
zuluman13's Avatar
Can a manual be competetive in bracket racing.
Old Aug 31, 2003 | 09:05 AM
GUMP's Avatar
A really fun class to run is IHRA Pure Stock. Get a rule book and check it out. If you build it right you won't spend a ton of money, you can still drive it, and you can run National events, Divisionals, and any bracket races that you want too.
And yes, sticks can be competetive too!!
Good Luck,
Daren
Old Aug 31, 2003 | 05:34 PM
We have a local 9 second stick car. He does pretty well but the best consistancy is with an automatic.
whitehooptie
Aug 10, 2015 07:02 AM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Boss002
May 20, 2015 12:55 PM
