correct air pressure nitto 555 r ?
Old Jul 1, 2009 | 07:34 PM
RalphBoggero's Avatar
whats the correct air pressure for a nitto 315 35 17 555 r at the drag strip ?
is 14 pounds correct? thanks
Old Jul 2, 2009 | 02:45 AM
toomchz4u's Avatar
I don't think there is a correct pressure. Whatever works best for you is what I would consider the correct pressure. I have these and I've only made 14 passes on mines and 18 psi seems to work best for me so far.
Old Jul 2, 2009 | 01:53 PM
AutoRoc's Avatar
19-20psi HOT a SERIOUS burnout works ok for me. Get them HOT!
Old Jul 2, 2009 | 08:11 PM
thanks for aswer Ill trywith 18 pounds
Old Jul 2, 2009 | 11:01 PM
Z-RATED94's Avatar
No more than 18 hot. You need to do a John Force type burnout too. BTDT
Old Jul 3, 2009 | 12:55 AM
yes I have to heat em well. a lot of smoke huh?
Old Jul 3, 2009 | 10:56 AM
Z-RATED94's Avatar
Yes. Aim your side mirror to look more towards the quarter panel. After you get them spinning (don't be shy with the wheel speed) take a peak in the mirror and make sure you get at least 3-4 seconds of good smoke.
Old Jul 4, 2009 | 01:55 PM
96SSIndeed's Avatar
yes lots of smoke. i use 22psi with a really HOT burnout, and dead hook with a rediculously high rpm launch
DirtyDaveW
Dec 1, 2016 05:37 PM
sloppytot
Feb 25, 2015 08:30 PM
Jason Short
Jan 19, 2015 06:33 PM
95chwagon
Jan 13, 2015 09:19 PM
jp2002ls1
Jul 22, 2002 04:18 PM
