cool temps = new best et.
Old Oct 16, 2006 | 01:22 PM
KEITHZ06's Avatar
shaved a whole tenth off my best e.t. temp was 48 degrees and corrected altitude was -278. I still don't have the best 60 foots but I am working on them.
60' 1.431
1/4 mile 10.421 @127.15 still a n/a LT-1 383
Old Oct 17, 2006 | 01:46 PM
2000GTP's Avatar
Re: cool temps = new best et.
Your haulin. Very nice.
Old Oct 17, 2006 | 03:34 PM
TQdrivenws6's Avatar
Details on the combo?
Old Oct 17, 2006 | 03:35 PM
CamaroRacing12's Avatar
wat does that magnum run?
Old Oct 19, 2006 | 04:22 PM
KEITHZ06's Avatar
Basics on the car 383 with afr heads and holley commander 950 fuel control with holley throttlebody. 4.88 gears and a turbo 400 trans. Converted to manual steering, race weight 3100lbs.
I can't find the time slips on the Magnum I think it was high fourteens and around 98mph. If I can find the slips I will post them.No traction problems with the AWD !!!
Old Oct 19, 2006 | 07:25 PM
The Engineer's Avatar
That is a really fast N/A 383 considering the race weight. Which # AFR LT heads and cam are you running? Also what size slicks w/ the 4.88s and what is your trap RPM.
My LT 396 w/ AFR 195s has a best of 11.22 @ 119.3 (1.61 60ft) w/ a 3485 race weight (3.73s and 26" ET Streets). I'm planning to add a 12 bolt w/ 4.30s and 28" slicks which I hope move the 60 ft times down into the 1.50s.
WD
http://www.cardomain.com/ride/2189634
Old Oct 19, 2006 | 08:35 PM
93turbo5oh's Avatar
can you tell us more about the holley eft system? is it an lt based motor or sbc based?
Old Oct 20, 2006 | 05:32 PM
KEITHZ06's Avatar
I have the 190 LT-1 competiton package heads which I beleive are no longer available.
The camshaft is a custom grind by my engine builder.
trap rpm is right around 7600
I am using 29x10.50x15 hoosier slicks.
The Holley system is for the lt1 engine I use a fuel map that Holley has on there website that we have made some modifications too. It is programable with a laptop and has the ability to" go along for the ride" to see what is going on.
Old Oct 20, 2006 | 07:28 PM
Those AFR heads don't appear to be too large. Also, what compression ratio are you running?
Old Oct 21, 2006 | 11:52 AM
KEITHZ06's Avatar
12.8 J&E pistons were used. Motor was built in 2001 I put 300 runs on it and did a freshen up winter of 04-05 it showed no signs of wear.
jerrysims71
Aug 15, 2015 12:47 PM
Aug 7, 2015 01:26 PM
4586
Aug 2, 2015 01:45 PM
4586
Jul 31, 2015 06:03 PM
Noct
Jul 14, 2015 01:18 AM
