convertible racing
Old 11-25-2005, 12:31 PM
JS02's Avatar
convertible racing
Can a vert be made to compete with a high horsepower"600" or will it flex too much
JS02 is offline
Old 11-25-2005, 04:59 PM
MBonZ28's Avatar
Re: convertible racing
you obvioulsy have never heard of Gearge Baxter. Car went 9.04 with an LT1 and for awile was the fastest 4th gen around. He ditched the LT1 and started running Extreme street in the PRO series with a blown SBC. I think the car got down to the 8.70s
it is a must to get some aftermarket subframe connecters and you will be even better off with a cage tying it all together too. Convertibles run a little heavier but who cares, chicks dig em!
MBonZ28 is offline
Old 11-25-2005, 05:22 PM
Moderator
rskrause's Avatar
I have weld-on SFC's and a good, welded-in 6-point bar and it's not an issue. A full cage would obviously stiffen it up even more, but full cage and street cars do not mix, IMHO.
Rich
rskrause is offline
Old 11-25-2005, 11:02 PM
George's best with the 30th SS convert was 8.60 @ 160+ mph. It was making about 1,325 flywheel HP at that point, and weighed about 3,525#.
Injuneer is offline
Old 11-26-2005, 10:50 AM
JS02's Avatar
Thanks for the info. I have a 97 SS 6M low mile car that I am considering trading for a low mile 97 SS vert. it has a 383 vortech. I was just wondering if subframe connectors would be enough to keep the frame from flexing too much.
JS02 is offline
Old 11-26-2005, 10:49 PM
If you run an NHRA track, you're going to need a roll bar. That will add some stiffness to the chassis.
George's original setup ran about 750 flywheelHP, and he used a relatively inexpensive set of MAC subframe connectors. I don't think he ever replaced the MAC's, but I know that there was a lot of work done stiffening the floor pan between the SFC's to handle the loads from a torque arm mount, first the Madman TA, and later the Spohn TA. And once it went into the 9's, it had an NHRA certified cage, which added sustantially to the chassis strength.
His only regret with regard to starting with a convertible was the 100# of extra weight. It was sort of interesting to see him drive the car to the track with the top down, make a 9-sec pass, and then drive it home. It only went to the track on a trailer when he decided it needed to get deep in the 9's.
Injuneer is offline
thenewkid
04-12-2015 07:42 PM
CARiD
04-08-2015 08:08 AM
Z28amustangklr
Middle Atlantic
03-28-2015 03:08 PM
mark0006
03-21-2015 12:32 AM
thenewkid
11-27-2014 09:41 AM
Quick Reply: convertible racing
