Converter question?
Old Feb 24, 2004 | 07:32 AM
rje's Avatar
rje
Converter question?
I was wondering how much mph does a loose converter eat up in the 1/4 vs a stock converter or even a manual trans.
Randy
Old Feb 24, 2004 | 04:46 PM
94ZRiCeKiLr's Avatar
M6s usually trap about 4 mph higher stock for stock....
Old Feb 24, 2004 | 10:44 PM
Gold Z's Avatar
As long as you get there quicker, who cares about mph..........
Old Feb 25, 2004 | 06:09 AM
rje's Avatar
rje
That's true, but I'm trying to figure out what kind of hp I'm making. When my car was a M6 and had the hotcam in it it and weighted 3600lbs it ran 12.0's at 115-116. Now with a larger cam, a TH350 with 4200 TC, and weighing 3450lbs it runs 11.7's at 114. I know the converter is hurting my mph, but I just don't know how much.
Randy
Old Feb 25, 2004 | 07:48 PM
MISOMWS6's Avatar
I'm not shure but you must be able to shift an m6 like a **** I would think you would be able to drop more than .3 off the new setup But like I said you can drive a m6 good so maybe the .3 is pretty good?
Old Feb 25, 2004 | 09:59 PM
rskrause's Avatar
Moderator
HP loss with a converter will vary not only with the design of the converter but also how much hp you are putting through it. The more hp, the greater the loss (both absolute and percentage). So, no way to say for sure or even make a good estimate.
Rich Krause
Old Feb 25, 2004 | 10:31 PM
Stephen 87 IROC's Avatar
Doing converter slip calculations for my car says I should be at 138.62 mph at the finish line but I'm only 128.47.
That gives me a 7.32% converter slip. Anything less than 10% is good for a race car.
ChrisFrez
Feb 15, 2015 07:49 AM
rwferguson43026
Feb 6, 2015 10:06 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
86ZZ4
Aug 22, 2002 08:50 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
