Convert Power To Manual Steering
Re: Convert Power To Manual Steering
madman and pa racing sell manual rack conversions. you can get them to with stock mounts,or buy the kmember and lose more weight also. hope this helps
ps,this should be in lt1 tech or drag racing.....
FJ Smith (www.smithperformance.com) has a nice piece. Their customer service is very good as well. Very friendly/helpful.
Ryan
Ryan
I got a Madman rack. Just like Smith's it's a Pinto-style rack w/ the bump steer kit. I got mine for a stock mounts and it went on my BMR K-member just fine. It's slightly lighter than stock (saved maybe 20# tops w/ the deleted pulley, lines, fluid and different rack) and the ratio is MUCH better than the power rack. Took about 2 hours to put on. I did have to drill out the holes on the spindle, but if you use a low-speed drill and plenty of fluid, it cuts just fine and won't crack.
Did you hve to change the steering box?Does he weld the mounting pads to the rack to fit fbodies or will they just bolt up as a stock pinto rack?
Thanks,John
Thanks,John
F'n1996Z28SS
Aug 23, 2023 11:19 PM
stockssn2o
May 25, 2015 08:54 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
