Convert Power To Manual Steering
Old Aug 24, 2004 | 01:43 PM
Black Cloud's Avatar
Does anyone know or have done this swap before?
Any help is greatly appreciated.
John
Old Aug 24, 2004 | 01:52 PM
RacinLT1's Avatar
Re: Convert Power To Manual Steering
madman and pa racing sell manual rack conversions. you can get them to with stock mounts,or buy the kmember and lose more weight also. hope this helps
ps,this should be in lt1 tech or drag racing.....
Old Aug 24, 2004 | 04:23 PM
kmook's Avatar
Advanced Tech Moderator
I'll transfer this to Drag Racing since it doesn't really fit here or in LT1 "engine" Tech.
Old Aug 24, 2004 | 09:39 PM
96speed's Avatar
FJ Smith (www.smithperformance.com) has a nice piece. Their customer service is very good as well. Very friendly/helpful.
Ryan
Old Aug 25, 2004 | 09:40 AM
mongse_1's Avatar
I got a Madman rack. Just like Smith's it's a Pinto-style rack w/ the bump steer kit. I got mine for a stock mounts and it went on my BMR K-member just fine. It's slightly lighter than stock (saved maybe 20# tops w/ the deleted pulley, lines, fluid and different rack) and the ratio is MUCH better than the power rack. Took about 2 hours to put on. I did have to drill out the holes on the spindle, but if you use a low-speed drill and plenty of fluid, it cuts just fine and won't crack.
Old Aug 27, 2004 | 10:08 AM
Pro Stock John's Avatar
Madman rack bolts in very easily, you have to drill out the spindles a little but it's easy.
Old Aug 27, 2004 | 10:16 AM
Did you hve to change the steering box?Does he weld the mounting pads to the rack to fit fbodies or will they just bolt up as a stock pinto rack?
Thanks,John
Old Aug 28, 2004 | 03:39 PM
madman69's Avatar
Give me a call 281-290-8899 and I can explain everything.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
XtremeLt1
Sep 13, 2002 08:50 PM
