better gear?
Re: better gear?
M6 or A4?...Generally A4s use 3.73s and M6s go with 4.10s...I used 3.42s in my 10 bolt for years, Put a Strange 12 bolt in last year with 3.73s....I'm an A4...Depends also on goals for the car, cam size, tire height, etc...
--Alan
--Alan
Re: better gear?
Too many other factors.
Engine rpm range
Cam grind
Torque converter stall if an automatic transmission
Transmission gearing
Tire size
Vehicle weight
You need enough gear so that you cross the finish line at or just before your red line in high gear, not OD.
If you cross the finish line before you red line in high gear you need more gear so 3.73 would help. If you run out of rpm before you reach the finish line then less gear is needed and 3.42 would work.
Engine rpm range
Cam grind
Tire size
Vehicle weight
Re: better gear?
--Alan
--Alan
Generally speaking that means 4.10s but as posted above, peak power rpm and tire size are the main determining factors.
Re: better gear?
As Al stated, there is no answer to the way you have posed the question. My Camaro has 3.42's and my race car has 4.86's. Both trap mid 140's and both gears are "best" for each application. the variables are tire size and rpm range, in that case.
Rich
Rich
Re: better gear?
Originally Posted by Stephen 87 IROC
Ya but fun. I have to try and keep it under 150 mph this year so I don't have to install a parachute.
Rich
Re: better gear?
Originally Posted by rskrause
I bet they came up with that 'chute requirement back in the days of drum brakes. I can easily stop in maybe half the run-off area at my local track, without the 'chute. I do have one on the race car though. I think a more reasonable speed would be 175 or so in this era of good brakes.
Rich
Rich
Re: better gear?
Actually the rule states you need a parachute at 150 mph but don't need to use it. I saw an old Nova run 12 seconds with drum brakes that almost needed a parachute to stop.
My car still has the factory disk on the front. I have large ford drum on the rear. I don't like slowing down hard to take the first turn off but can easily make the second turn off.
ChrisFrez
Mar 22, 2015 09:12 AM
