Backhalf 4 link project need info
I have a 9 firebird and im going to put a 4 link in the car and tub the car is there any 4 link frame setups i can buy from summit or jegs to help me get started. I talked to a guy that builds tube chassies for race cars around here and he is sayin 5g for the 4 link set up including rear end and rims and tires. I was going to goahead and start buying the parts to bring to him but not sure what to bring if anyone has done this let me know
Re: Backhalf 4 link project need info
It would probably be cheaper to get him to do it. There's a lot of alignments required when welding in a back half. How's you MIG skills? Got a 220V MIG welder? Tig would be better and cleaner. If you weld in a bracket that's not in the proper position, you won't be able to change the 4 links without a lot of realignments.
The kits themselves are not expensive but there's a lot of time and labour required to put one in properly. I'd say 5 grand is really cheap for everything. You can buy a complete kit for specific vehicles. Usually includes frame rails, all the 4 link stuff, shocks, and a diff housing.
Summit sells these kits starting at $1,129. It doesn't include axles, diff center section, rims etc. After it's all in, the car still needs a bunch of tin work to seal everything back up since the entire rear floor from behind the front seats to the very back gets cut out.
Check out S W Racecars they have a rear frame kit. It says it is for a 3rd Gen but I emailed them and they said:
"Yes it will work in the 4th generation. You will need to trim the crossmember and frame rails down a few inches, but it will work for the car. Let me know if you have any other questions."
That is a copy of the email they sent back to me. I plan on doing that myself. Hope this helps you.
sc93
Jul 26, 2002 02:02 PM
