Another "guess my time" thread
Old Oct 3, 2008 | 02:35 PM
seawolf06's Avatar
New setup and I've never run an 1/8 mile. What would be average and what would be pretty good? I'd expect to have ~400rwhp. Also, should I shift into 4th at all with 275/45/17's and 4.11 gears? TIA
1995 Z28 M6
K&N FIPK
52mm TB
ported intake
stock, ported World Challenge heads (flow better than LT4 heads)
Comp Cams 1.6 RR
Manley 2.0/1.56 valves
42#/hr racetronix injectors
LE 2.2 cam
Mahle 4.040 forged/coated pistons
Mezeire electric waterpump
MSD optispark
LS1 aluminum driveshaft
pcmforless tune
BMR LCA, relocation brackets and BMR PHR
MSD 6AL
SLP 3-point SFC
Old Oct 3, 2008 | 03:48 PM
30AnniversaryZ28's Avatar
In an 1/8 mile I doubt you'll have to shift into 4th. Granted I have 3.23s, but I was just shifting into 3rd crossing the finish, shifting at ~6500.
Old Oct 3, 2008 | 03:57 PM
seawolf06's Avatar
How much power are you putting down?
Old Oct 3, 2008 | 04:28 PM
It put down 333 hp and 390 tq, but was really lean (16:1) above 3500. The guy running the dyno said getting the correct a/f ratio would give me another 30-40 hp easy.
Old Oct 3, 2008 | 04:45 PM
seawolf06's Avatar
333rwhp and you ran a 8.2?
Old Oct 3, 2008 | 06:28 PM
Like I said, the power is really low, but it still has almost 400 ft/lbs. I spun off the line all through 1st (street tires) as well.
Old Oct 5, 2008 | 05:54 PM
seawolf06's Avatar
Best I could manage was a 8.475 @ 88.01mph spinning all the way through first. I need to find a better track, lol.
2.185 60' - Could use some work on that, too, but I didn't want to shred the rear end.
Old Oct 5, 2008 | 06:36 PM
Your MPH is good, like you said, get that 60' down and you could possibly be in the 7s
Old Oct 6, 2008 | 07:02 AM
seawolf06's Avatar
Unfortunately, somehow a valve was bent or something and it's stuck, so I won't be back anytime soon.
n2oblkz
Oct 22, 2015 02:31 PM
Greg88
Sep 20, 2015 07:14 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
