Airbag Sensor Under Center Counsel
Old Oct 14, 2003 | 08:55 PM
Victory Racing's Avatar
I removed the passenger airbag from the car, but I am leaving the factory steering wheel. I don't want to screw with removing the airbag from the steering wheel so I plan to just leave it there.
My question is this. If I unplug the yellow airbag sensor under the center counsel, will that cause the airbag to false?
Thanks for any help.
Old Oct 14, 2003 | 11:36 PM
CSJTA's Avatar
I don't think it will. I believe, the part under the center console, fires the Airbags when they are told to deploy, so if you unplug it, you should be okay.
Old Oct 15, 2003 | 12:04 AM
96speed's Avatar
AFAIK, If one airbag is removed neither will fire. If the "airbag" light is illuminated the SRS system is disabled - just like the ABS system.
Ryan
Old Oct 15, 2003 | 12:53 PM
Ken95Z28's Avatar
What's the weight on the bag?
Old Oct 16, 2003 | 08:52 AM
mongse_1's Avatar
IIRC, the passenger side airbag is fairly hefty. It's also a little more difficult to remove. I'm taking both of mine out(already removed all the firing sensors). With the 5-points in the car, all the airbags will do is inflate right in front of my face.
Old Oct 17, 2003 | 07:28 AM
8850's Avatar
Does the air bag light come on if you unplug this sensor? Any other ill effects?
Passenger air bag = 14 pounds. Drivers bag = 4 pounds.
Victor Lamb
Aug 26, 2017 02:52 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
4586
Parts Wanted
May 20, 2015 10:48 PM
Drtryder
Apr 22, 2015 04:17 PM
stik6shift98
Jul 17, 2002 11:13 AM
