Adjustable Shocks for Racing/Street
Old 10-01-2003, 11:16 PM
BlakeW5's Avatar
What adjustable shocks do you guys use for racing (not drag shocks)? I've been looking at Illuminas, HALS, etc. I want a shock I can tune in for the strip, then change back to a street ride. Also, exactly how do they adjust for launching, what I mean is should the front end be soft for weight transfer and the back shocks stiff (or is it the other way around)? Also, can I get by using just a front pair or a rear pair of shocks?
BlakeW5 is offline
Old 10-02-2003, 08:27 PM
Mike Comp T/A #57's Avatar
What adjustable shocks do you guys use for racing ?
* I use QA1 12 way adjustable on all 4 corners. I have them all set on the #4 position on the way to/from the track. When I get to the track I set the front's on #2 ( position #1 is the softest setting) and the rears on #3. My drag radials are junk and the track was not prepped last time out so I had to put the front's on # 1 and the rears on #2. You want all 4 shocks to be stiff as possible, so if my tires were good and the track was prepped with VHT.......I probably would have the fronts on #2 or #3 and the rears on #4 or #5.
Mike Comp T/A #57 is offline
G-BODYT56
01-14-2022 11:14 PM
93 RedBird
11-15-2015 08:24 AM
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
football4life
10-04-2015 07:48 AM
SEOJustin
09-24-2015 04:39 PM
Quick Reply: Adjustable Shocks for Racing/Street
