18" hurt 1/4 mile, how much?
Old Oct 19, 2003 | 07:46 AM
cozmo's Avatar
Anyone know how much 18" rims hurt your 1/4 mile time vs 16"? Is it .1 or .2 or more like .5? Thanks
Old Oct 19, 2003 | 10:04 AM
TedH's Avatar
Not enough detail and way too general of a question to accurately answer. The heavier the rim/tire combo the slower it is. 18's are often heavy. A taller sidewall is good for launching as opposed to ashort sidewall. However a longer rollout can help ET's.
Old Oct 19, 2003 | 11:13 AM
cozmo's Avatar
Assume that the same 60' can be achieved and that the only thing that hurts the time is the weight of the rims. Lets say they weigh 5 pounds more than stock. Does that help any?
Old Oct 20, 2003 | 01:24 PM
TedH's Avatar
If you are simply talking about 5 pounds per rim on a 3600 pound car, the impact will be nill.
Old Oct 20, 2003 | 04:57 PM
cozmo's Avatar
I found out that the 18" rims I have weigh 23 pounds. How much do stock 16's weigh?
Old Oct 20, 2003 | 05:28 PM
Alex 97Z28 M6's Avatar
It's been awhile but I believe stock '97 painted wheels run about 19-19.5lbs each. My C5 wheels weren't much different than my stock wheels, the 17s weighed exactly the same as the stockers and my 18s out back were about 21.5lbs each.
What you should be more worried about is how much the tire and wheel weigh compared to stock. Tires can vary by manufacture as far as how much they weigh. It can be +/- 5lbs (each) from one manufacturer to the next! Wheels play a part in the weight, but tires can play an even bigger role.
Old Oct 20, 2003 | 05:45 PM
cozmo's Avatar
The front tires actually weigh 2.4 pounds less, and the rears are the same.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
