Wiring in a new Tachometer
Re: Wiring in a new Tachometer
Originally Posted by WS Sick
If it is an unfiltered LT1 (late 95 and up you can use the white wire from the ECM to the in dash tach If I remember correctly.
Originally Posted by LWillmann
But, if the in dash tach is known to be off from actual RPM, then what's the point of using the PCM output for the tach?
Originally Posted by cmking26
Its a 94. Anybody know how to do this?
I'm not sure where the tach filter is, but it has to be removed to use the white wire with an after market tach. Not positive on the years either, I just had a freind tell me he thought the 93s were the only year with the filter inline for the factory tach, then again I had another freind tell me it was any LT1 with the dual coild connectors instead of one. I'll have to let someone that knows more tell you that.
I wired the one on my LT1 S-10 from the ECMs white wire, It more than likely is the same wire on the coil, it looks so according to the wiring diagram for our cars.
Shoeboxs site has the wiring diagram on it.
White wire black connector. (pin 13 or 15, maybe 16 don't remember)
I have a 94 also and an aftermarket tach, hooked up fine with no other
issues, also it's faster that the indash tach and seems to be right on with tunercats rpms.
surreybrad
Apr 22, 2015 06:40 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
