Wideband O2 opinions
Old Nov 24, 2005 | 09:46 PM
Slow260z's Avatar
Has anyone seen this wideband wideband O2 system
Isn't cheap, but at $279 the best I have seen. I'm not sure it is fast enough since the sample rate is 74/sec seems it will fall short at upper RPMs.
It includes the output to simulate the narrowband O2. Should allow accurate self tuning unless I am missing something has it all for $279
Another one suggested to me is Another O2 system
But the one I linked first allows multiple inputs (RPM, Throttle Position sensor, MAP, Boost, AFR, etc) to be collected and linked in time.
Seems the other has has narrowband output, but I'm not sure it provides these collection capabilities.
Old Dec 4, 2005 | 12:42 PM
Slow260z's Avatar
Re: Wideband O2 opinions
No one has an opinion?
Old Dec 4, 2005 | 08:30 PM
NYSS Guy's Avatar
I have the Innovate LM-1. Although, had I known before I ordered, I would have ordered the LC-1. You can hook LC-1 directly into HP Tuners. You can do the same with the LM-1, but the LC-1 is cheaper. My experience has been good with the Innovate product. G/L.
Old Dec 4, 2005 | 09:12 PM
Slow260z's Avatar
Thanks but doesn't that require a board to convert RPM data? The one I linked seems to have it all for $279.
I am asking I am not certain
Thanks for input
Old Dec 5, 2005 | 08:01 AM
NYSS Guy's Avatar
If you have HP Tuners, then all you need in the LC-1. HPT will log everything for you. If you don't have it, then you need the LM-1 and the rpm converter. From my experience, it's better off to have HPT and the LC-1. But if you don't plan on tuning at all, that may not work for you. Good luck.
Old Dec 5, 2005 | 10:53 AM
97WS6Pilot's Avatar
The Zeitronix Zt-2 seems to be the best bang for the buck. I'm interested in this one also. I did a search on here and there is not much info.
Old Dec 5, 2005 | 06:25 PM
Slow260z's Avatar
I guess I didnt specify. My intention is to tune my NA LT1 and then a supercharged LT1. I presently have Datamaster, Tunercat and would like a wideband to aid in 'proper' tuning.
My excuse is that this should save dyno expense and provide similiar results for NA car and get the Supercharged setup close enough to justify the expenditure.
It is a hobby so doesn't make sound economic sense but as a hobby it isn't that bad I hope anyway.
Thanks for input was extremely helpful.
Old Dec 6, 2005 | 11:21 AM
LWillmann's Avatar
I use the Dynojet Wide Band Commander. 2-1/16" gauge on the A-pillar. Logging capability built in too. Very nice setup!
Old Dec 6, 2005 | 01:23 PM
Slow260z's Avatar
That is a nice setup but from what I saw it is $579. I am sure it has great feature but I am trying to do it on the cheap. Since I have a laptop I have a larger investment that should save some by not requiring a guage.
Thanks for the input
Old Dec 6, 2005 | 04:00 PM
Check in the N2O TEch forum. One of the supporting vendors there was promoting a dual-band wide-band controller. I asked him how it compared to the Altronics O2 Alert, he indicated the unit cost less and had more features. Might be worth a "search".
This is the Altronics unit:
http://www.altronicsinc.com/pages/o2alert.html
Old Dec 7, 2005 | 07:31 AM
LWillmann's Avatar
I think mine was only $475 or so. Still expensive I guess, but worth it IMO.
Old Dec 8, 2005 | 06:18 PM
Slow260z's Avatar
Great ideas but makes the @279 look cheap now. The others are great IF you need the features, personally I do NOT.
I do like the one that can be dual channel but I can 2 X 279 and still beat that setup. If I need or wanted to shut down at a lean point that only requires an op amp and bingo.
Thanks again for inputs but from what others have suggested and my requirements I havent seen anything that matches the setup I suggested.
Thanks again
Old Dec 11, 2005 | 01:53 AM
Slow260z's Avatar
"Unequaled state of the art digital technology. No, not the least expensive, but unsurpassed pro quality monitoring accuracy at a very amateur price. "
Ok tell me what the 'digital technology' system will achieve that the system I mentioned will not?
"Something you won't get with the lesser priced analog choices."
Ok be specific tell me what I will get that is lacking for the other system. I want to make the right decision and facts will make the decision obvious.
"The old guard state of the art Horriba (analog) is not in the same ballpark as this digital Innovate product."
Wow from your post I can't wait to read all the features it has that the system I asked about doesn't.
I DEFINATELY look forward to hearing the information that verifies your statements.
Jack
Old Dec 11, 2005 | 11:18 AM
Slow260z's Avatar
First off Jack, the Innovate product (LM-1) will not meet the above price.
Ok so the LM-1 costs more than the alternative I suggested. So, given that is a fact where are the specifics on it’s capabilities compared to the wideband system I linked? I stated I feel the unit I linked is slow how fast (samples/second is LM1)?
With highly suggested and worthwhile options the price is more like $500. It can go up from there.
So now you are saying the Innovate system is closer to twice as expensive, so what superior capabilities justify the additional cost? The system I linked has RPM capability and other inputs that we all know after reading the link.
To put in perspective, so the $279 is not as accurate. Just about any WB controller/sensor will be lite years more accurate that the OEM NBO2 is when it is expected to do what it was not engineered to accomplish.
The $279 unit is a wideband unit, and is all that is required to collect tuning data.
The price includes the wideband, controller and software for data collection. What are you talking about? It has all that is needed to collect WIDEBAND data with RPM. Did you not read the link I provided or not understand it?
What else is REQUIRED? Yes many sensors could be added, but to accurately tune AFR the linked system is sufficient unless someone shows specific data required that it will not provide.
That is generate actual AFR figures. As most know, it is just a switch that is accurate around stoich. So it is not as accurate as the LM-1.
The unit I posted is a wideband. Yes the stock units are a simple switch. That is why we have this discussion.
I requested information about units. If one unit is superior here is the time to CLEARLY show examples NOT manufacture’s claims, or smoke screens.
It will still probably more accurate than the variation of AFR among the 8 cylinders at a given RPM. AFAIC, to do the LM-1 justice, monitoring of each cylinder is a good idea. Anyone that designs an intake or even makes mods to existing OEM intake and believes the airflow to @ cylinder is equal without good research and test procedures is taking a lot for granted
Gary so are you telling me the LM1 will allow fuel trim measurements and changes?
Using Nyquist theorem 74 cycles a second will ALLOW AFR measurements at ~4400 RPM for ONLY each bank!
To be able to determine idle trims of course means ~4400/4 = 1100 RPM. So to determine cylinder trims at WOT and 4400 RPM would require as a MINIMUM a sensor that is 4 * 74 cycles a second. Then of course we would have to discuss how to hold an RPM point to collect sufficient data for the data to be statistically sufficient to be useful to change trims. To say the least that is another can of worms.
IF a system is superior it should be easy for anyone to be specific about the system without anger or other silliness often seen on line.
First off, just cuz a product uses a digital gauge to read the AFR, does not make it a digital product. The digital technology is inside the controller.
I don’t care if one is analog or digital I only care about price and performance. I consider it a black box and standing outside I only care of results. I am a Electrical Controls engineer so please save the hyperbola, I help write the BS so many hang their hats on.
The LM-1 uses a different and pat. pend. measurement principle. To go into the difference specifically is beyond the discussion here. The end result is allowing it...
Sounds like you are saying it is better, but you can’t tell us how? Well just trust me won't cut it.
In God we trust, all others pay cash, and show data to prove their point. I am an Engineer and not impressed without DATA.
* extremely fast reaction time without overswing.
What is sample rate? How many sensor samples read per system output? etc.
* independant of component tolerances which is big thing with any other unit despite what the mfr. may want you to believe.
What is that supposed to mean? Seems to say the design takes into account component tolerances? All decent designs do.
* compensatation for sensor drift due to age.
So how does this compare to sensor calibration contained in the other unit?
* less susceptible to exhaust back pressure.
What wideband sensor does it use? I was told they both use the same wideband sensor. Since you do not believe this what sensors does each unit use?
* calibrate for actual sensor characteristics independent of factory calibration resister inside sensor which is correct only when sensor is new.
How is the LM1's calibration superior? Seems both will use the same principals from physics.
* and has automatic compensation for 'rich gas loading' which is responsible for it's own issues.
Explain I bet many would love to hear all about the items you brought up.
Hope what I DID post will be of help.
If you answer questions and provide specifics it might. I’m sure many would love to hear the details, as you have posted you have simply caused more questions and made the LM 1 look inferior from your lack of specifics and reliance on buzz phrases.
Safeguards designed into the LM-1 (which competitors do not have) to insure the accuracy of the unit due to the advantages above,
Another example of specifics people want to hear data on.
have caused the novice, those that do not familarize themselves by reading the manual through thoroughly or those with special applications, difficulties and has generated complaints about the product. Remember, it is those relatively few by comparison that have problems that are vocal, not the many satisfied ones. Enuf time spent on the forum will reveal this.
I have no axe to grind. I want specifics. If one is superior I would like to see the data many love their unit, but no one has shown me data to justify their claims.
As a controls engineer I help write the claims being stated here. Sales promotion is important for sales of any unit, BUT the wording is always mere play on words and seldom is any product much different than the other.
Unless of course you ask those that own it, then or software with patent pending algorithms become superior to even Eienstein’s theories.
I asked for specifics, and would still like to read specifics. If you can NOT provide SPECIFICS then simply do not respond. I personally do not care what system is best. I want SPECIFICS to evaluate the systems, many simply repeat the manufacture’s claim which tells me that buyer does not understand the process they are trying to discuss.
Thanks for the insight.
Old Dec 11, 2005 | 05:03 PM
A/G's Avatar
A/G
I figured you would understand what I stated. Now you want to compare a better unit with suggested options to a bare bones alternative without any options. Apples to oranges. I guess I didn't explain it well or you misunderstood.
Smoke screen? LOL. I'm not selling anything here, just bringing to your attention a superior product. No, not my opinion. The idea was to get you (if interested) pointed in the right direction if you chose to learn more. It is easier to say I am merely blowing smoke than to do the homework and prove otherwise.
Not at all. As posted, beyond discussion here. If you want to learn more, why wear out my legs (or fingers)? I have nothing to gain if you buy Innovate.
Not true. Homework will bear this out unless you chose to in this instance, believe mfr. claims.
Several pros that understand the capabilities of the LM-1 have chosen it for that reason. The average enthusiast is primarily concerned with just AFR, and an average of several cylinders at that. As an engineer I'd think you'd appreciate superior engineering and not label it just a 'black box'.
EDIT: Was just attemptiong to help out, not become a whipping post.
