Why is it that Datamaster only records up to 6375rpm?
Old May 18, 2003 | 10:12 PM
Dan K's Avatar
Anybody know?
I've got quite a few dyno logs and just now noticed that at 6375rpm it quits measuring rpm.
Is the "creator" of datamaster still hanging out here?
Old May 19, 2003 | 02:21 PM
Its an 8-bit field, with 25rpm per bit.
255 x 25 = 6375
No, I'm not the creator of DM.
Old May 19, 2003 | 06:10 PM
Dan K's Avatar
And I know you didn't write the program!
Old May 23, 2003 | 08:07 PM
Rufus's Avatar
Dan,
There is a new version of Datamaster out that will display up to 10,000 RPM. This data comes from the DRP (distributer Pulse Rate) and has no upper limit. The data item is called "RPM16"
There is a beta copy of this available for download at http://www.ttspowersystems.com/ . Scroll to the bottom of the downloads page, that is where all the Beta software versions are.
HTH,
Gary
Old May 24, 2003 | 12:38 AM
Dan K's Avatar
I'll check it out. Thanks Gary.
EDIT: The beta version works perfectly...for you guys spinning your car past 6400 check it out!
karpetcm
Dec 16, 2015 09:07 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
karpetcm
Sep 29, 2015 10:08 AM
Bails098
Aug 17, 2015 05:15 PM
Aug 7, 2015 01:26 PM
