Where to download tune
Old Nov 4, 2009 | 06:28 PM
7designs's Avatar
I have heard that you can download tunes others have done for their setup that matches yours. Where can I find this?
I have a 97 ss 6speed that i am putting long tube headers and cc306 cam, gmpp 1.6 roller rockers, springs.
Will be swapping in 95 pcm and knock sensor and tuning with tuner cat.
Old Nov 4, 2009 | 06:47 PM
LearJet's Avatar
you can look on the forums at monodax.com, also a google search will locate a few other places. I don't recommend doing this however. Your best bet would be to have pcm4less send you a custom tune for your specific mods to start with and then go from there.
Old Nov 5, 2009 | 10:29 AM
bobdec's Avatar
Be cautious, it's sort of like downloading anything, you can't trust what you get. If you know enough to verify the tune first then try with caution. I have download quite a few tunes from those sites that were downright wrong. Supposedly modified cam tunes claiming 375 HP that were just about 99.9% stock settings, etc.. etc... If you have TunerCat for OBD1 then just do a search on ' LT1 PCM tuning' and check out the hits.. you can get an emailed load it yourself w/tunercat tune for $65.00 that's customized to your car and has updates based on your feedback.
Old Nov 9, 2009 | 05:58 PM
The Untouchable's Avatar
whats better for tuning a 93 Z28 LT-1edit or tunercat? you can pm me the answer and your opinions if yall want
Old Nov 11, 2009 | 01:39 PM
koolaid_kid's Avatar
I used LT1Edit for my OBDII tune. I found it extremely limited in its capabilities, poorly laid out, lacking the 3D graphing it suggested it had, and far too expensive for what you got. Plus I found it poorly supported by the vendor.
I am in the process of converting to OBDI and chose Tunercat. Way more flexible, and actually supported by the vendor.
Old Nov 17, 2009 | 10:07 AM
7designs's Avatar
I decided to go with obd i conversion and tunerPro rt.
DirtyDaveW
Dec 1, 2016 05:37 PM
May 15, 2015 10:43 AM
95z_28_camaro_4_Ivan
May 10, 2015 09:28 AM
ChrisFrez
Apr 5, 2015 05:54 PM
ChrisFrez
Mar 29, 2015 09:43 PM
