When is it time for a custom computer program?
Old Nov 4, 2003 | 07:52 PM
z28s's Avatar
Just wondering what mods to have before getting a custom program for my computer..when is it pointless? when is it needed?
Thanks..
Tony
Old Nov 4, 2003 | 08:25 PM
DOOM Master's Avatar
Well, I suppose it depends. Something as simple as a gear change/wheel change can throw off your transmission shift points and/or your speedometer. Other things such as cam change, displacement increase, etc. can almost require a reprogram to run correctly. Otherwise you end up with things like poor mileage, surging during acceleration, and running too rich/lean. With your car it probably wouldn't be a bad idea to get a reprogram for your gear and wheel change. You really don't have any other mods that would greatly benefit from a tune, although even a stock/bolt-on car will still benefit from a good tune. You could probably get an extra 10-15 HP out of a good tune.
Old Nov 5, 2003 | 06:49 AM
doodad's Avatar
I was running rich after header install and picked up 14 HP with a dyno tune. I think how the car is running and an A/F run on the dyno is the answer to the question.
Old Nov 5, 2003 | 02:54 PM
z28s's Avatar
Thanks, im planning on a rebuild in the next month or two..simple .030 over, possibly stroking, my brother will port and polish my heads/intake and a hotcam...im thinking i would benifit from a new prom after that....
thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
Absolute Z28
Jul 19, 2002 02:21 PM
