What is the computer on drivers side frame rail
Old Apr 24, 2007 | 07:58 PM
12SCNDZ's Avatar
Just in front of the front sway bar bracket, on the drivers side frame rail, there's a computer that's located behind the plastic splash guard. Is this the air bag computer? The car is a '93 Z.
Thanks,
Frank
CPT
Old Apr 24, 2007 | 08:41 PM
Daniel6718's Avatar
should be the cruise controal box? has a connector with a bunch of larger gauge wires in it...
Old Apr 24, 2007 | 11:08 PM
Sounds like you nailed it.
Old Apr 24, 2007 | 11:23 PM
Daniel6718's Avatar
sweet...off topic but shbox if you come back to this thread..theres a box inside the plastic on the passenger framerail about the same spot, has no electrical and one small line running to it, im assuming some sorta vacume canister from the factory? would i be hurt much be removing if from a 90% strip duty car, its light so i think that braking should be ok?
Old Apr 25, 2007 | 06:40 AM
12SCNDZ's Avatar
Yup..That's it. Thanks, Guys.
Frank
Old Apr 25, 2007 | 07:24 AM
Nice hijack. That would be the vacuum reserve tank for the HVAC controls. If you don't need to worry about your controls working at times of low vacuum, then you could remove it.
ChrisFrez
Feb 22, 2015 08:47 AM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
