Want to examine a .uni file?
Old Jan 22, 2005 | 08:22 PM
jpaugh's Avatar
3 Dyno runs and a .uni - Anyone care to take a look and give feedback?
Right-click, Save-As - www.imaliar.net/uni/nextleveldyno012205.uni
Old Jan 22, 2005 | 11:22 PM
Re: Want to examine a .uni file?
If you "export as .csv" from DataMaster, anyone with Excel can look at your file. When you post it in .uni format, you are limiting the viewing to DataMaster owners.
Old Jan 23, 2005 | 11:16 AM
Capt'n Two Rotors's Avatar
looks kinda lean to me, the blm are in the upper 150's.
Old Jan 23, 2005 | 11:35 AM
jpaugh's Avatar
Here you go Fred - www.imaliar.net/uni/nextleveldyno012205.csv
Capt - definitely lean, but can you really adjust for BLM's? Aren't they learned over time?
Old Jan 23, 2005 | 11:59 AM
You can adjust what the computer uses to determine rich or lean just a sec and i find a link for ya
Old Jan 23, 2005 | 12:09 PM
here ya go
If you are using a MAF sensor, then find where your logs show a BLM of < 126 or > 130. Note what the airflow number is at that point, and then go to that entry in the respective MAFS table in TunerCat. If the BLM was < 128 you will want to make the MAF frequency number lower. If it was > 128 you'll want to make it higher. The best way to modify the number is to multiply by %. Start with 1.025-1.05 or so, relog and see how the BLMs are affected at that airflow point. Repeat until the long terms are close 128
here a link http://members.nuvox.net/~on.roz/cars/z28/tuning.html
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
tommalcolm
Sep 11, 2015 03:39 PM
